2004 Silverado 1500 4x4 TCC Wiring
I have a 04 Jeep tj swapped in a 5.3L/4l60e from a 04 silverado, and trying to figure out the correct way to wire up the TCC. I have wired the tcc wire to a relay in a way that I get 12v on key on, and 0v when brake pedal is pressed, and I was told that is wrong, and that I should just run the tcc wire directly to the stop brake light so that the tcc wire receives 12v when brake it pressed instead.
below is how i wired the relay.
vorteciroc (Today)
Came across this circuit below, which is the opposite of what image above.
How to know for sure which way is correct?
LS1Tech Sponsor
Cant speak for the 2004 but on my 95 ss with 4l60e if the fuse for brake blows. you lose lockup. So at least in in e 95 pcm 12v is sent to the PCM from the normally closed side of the brake switch
vorteciroc (Today)
In most GM brake switches that I have seen there are at least 2 switches built into the 1 switch. 1 is normally open, this is used for brake lights and the other is normally closed which is used for TCC and cruise control.
The following 2 users liked this post by bbond105:
FranksCustomTrans (Today), vorteciroc (Today)
vorteciroc (Today)
This site may help LT1 Swap. LT1 Swap
vorteciroc (Today)
Man, I'm just trying to help. Your question has been answered by me and Frank with both of us giving the same answer. I have been an auto technician since 1982, and I am sure Frank has been doing his thing for a good while too. I don't know how else to help you.
vorteciroc (Today)
It is very simple.
The Two previous Posters have already stated this Correctly.
The TCC Positive Circuit receives 12 Volts+ when the Ignition is turned on, and when the Engine is running.
The ONLY time that the TCC Positive Circuit does NOT receive 12 Volts+ is when the Brake Pedal is Pressed.
There is ONLY one way in which this can happen.
The Brake Pedal Switch that is used for the TCC Positive Circuit is a "Normally Closed" Design Switch.
Pressing the Brake Pedal OPENS the Switch.
When the Switch is OPEN, Electricity can NOT pass through said Switch.
On the other hand...
The Brake Pedal Switch that is used for the Stop Lamp Positive Circuit is a "Normally Open" Design Switch.
This however has nothing to do with the TCC Positive Circuit.
-Marcello III
-Marcello III
