Bank 2 pulling too much fuel
kinglt-1 (10-01-2024)
You need to give some background information.
When did this problem start?
Is the car stock?
Why did you replace the injectors?
Are they stock injectors?
If not, has the tune been updated with the correct injector data?
Is the car stock?
Installed an LSA SC and have a base tune for it. Problem started after the install when I upgraded the ls1 fuel rail to the ls9 and new 60lb injectors. Tuner says the problem is mechanical. I changed plugs , O2 sensors and still have the issue. Did a smoke test and a leak down and I’ve got no leaks. Motor is far from stock but like I said I didn’t have the issue until I installed the sc. I can’t imagine new injectors and a new rail with 0 miles on it leaking but I haven’t checked that yet
Misfires leave raw O2 in the exhaust, which the O2 sensor interprets as running lean, which causes the PCM to reduce add fuel.
Is one of the headers primaries less hot than the others? Sometimes you can tell a difference just by licking your finger and tapping the header.
I went through this with my car over the spring/summer, and the root cause was a bad ignition wire harness.
kinglt-1 (10-02-2024)
Misfires leave raw O2 in the exhaust, which the O2 sensor interprets as running lean, which causes the PCM to reduce fuel.
I second the checking the temp of the header tubes.
NSFW (10-03-2024)
I appreciate the replies. It’s so frustrating. Yes I have several logs and with the key on engine off they are pretty close to the same. I tried another smoke test , even sprayed around the passenger side hoping I’d hear the engine die but no leaks. Pulled the plugs and all 4 from that side are equally soaked so I find it hard to believe all 4 injectors are leaking but that’s my next step. When I upgraded to the 0411 pcm I also upgraded the harness instead of re-pinning my 98 to eliminate wiring issues but could that be an option?
Sure thing. I have never uploaded a log file but I’ll try when I get home. The last log I saved the bar graph showed the bank 2 O2 sensor activity nearly top out in green almost the whole time which is where my screen shot showed the short term fuel for bank 2 at -39. I truly appreciate your help
I understand that, but you can still log them.
In the log, I have never seen a stock 02 sensor read above 1v before, even running stupid rich.
I'd think if it was a mechanical issue, with that big of difference between bank to bank, it would be obvious.
There is literally a 90% difference between the sides. There's no way to know for sure which 02 sensor is correct.
If you have the WB02 in the driver side, what's it reading? IF the stock 02 sensor is telling the truth, it should be super lean.
When I have the KOEO it reads 22.5. I never paid close attention to the gauge while it was running but I remember seeing it around the 7-9 region running. I can fire it up and re-check the guage while its running. I know zero about tuning I was just going off the word of my tuner that it was mechanical. Its super frustrating pulling plugs and sensors every couple of starts. I pulled the passenger siude yesterday and they were wet and black and disgusting. Ill pull the drivers side tomorrow and put new ones it before I start it to get you that number.
