Terminator X - How to configure 2-Step using voltage input
Then make an 5V input for your sensor
Make a 2D advanced table with the dwell or timing dump for the limiter function. I have found dwell works pretty well, used it for a few limiters before.
Use the above activation output as the switched enable for the advanced table, and use the 5V clutch sensor input as the Y axis and RPM as the X axis.
Do I need something else to build boost? Or do I have this configured wrong?
That ignition table is similar to how I have mine set up and it pops and bangs VIOLENTLY!... but will build boost in my manual car... never held it very long to see what it builds upto at a standstill cause of how aggressive the bangs are. I always feel like it's gonna blow apart haha
