PCM Hammer Won't connect
Old Apr 30, 2025 | 05:19 PM
BReal408's Avatar
Default PCM Hammer Won't connect
I have searched and can't find an answer. PCM Hammer keeps giving me a error message saying it can't connect. It is failing at the identify operating system it trys and fails asks me to enter the Operating System number which I do and it still fails out. Anyone got any ideas for me. Thanks in advance for your time and help.
Old Apr 30, 2025 | 05:24 PM
mrvedit's Avatar
Please tell us what model and year vehicle this is. Products like that don't work on everything, so we "gotta know".
Old Apr 30, 2025 | 05:48 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
And also what interface device you are trying to use. That has been an issue recently for a couple of people.
Old May 1, 2025 | 02:52 PM
BReal408's Avatar
It is a 5.3 out of a 2003 suburban and I have connected to it before. It sat for a while because I was going thru cancer treatment and now all of a sudden I can't read the PCM. I am using the OBSXPRO GT for interface. 12576106 is the os on tag of pcm. Voltage is good. Regular scanner reads fine.
Old May 1, 2025 | 04:13 PM
gametech's Avatar
Check your battery voltage. Pcmhammer does not do well with inadequate system voltage, and bad things can happen.
Old May 1, 2025 | 04:47 PM
NSFW's Avatar
This sounds like a hardware problem, something between your PC and PCM isn't doing its job. I'd start by double checking the wiring for power, ground, and communication.
If you click the "Get Properties" button I suspect you'll get an error message, and it might be helpful. But from the software's perspective, hardware problems generally all look the same: it can't communicate with the PCM.
Old May 1, 2025 | 07:35 PM
BReal408's Avatar
verified grounds and batterey voltage is good using obdxproGT to connect just keep getting an OS error
Old May 1, 2025 | 08:08 PM
mrvedit's Avatar
Will a basic scanner connect?
Old May 1, 2025 | 10:28 PM
BReal408's Avatar
Not sure I will try and get back to you. It will start and run with or without O2 sensors but takes a little pedal play to get it going. I am assuming that means I need to bump up my IAC a bit?
Now if I can just get into the PCM to do it...
Old May 2, 2025 | 12:41 PM
mrvedit's Avatar
Reason I ask if a normal scanner will connect is to determine if the problem is in the car or in your laptop connection.
I have encountered many problem with the OBD2 to Windows connection, whether with USB, WiFi or Bluetooth.
Many auto parts stores will perform a free scan for you.
Old May 2, 2025 | 04:07 PM
BReal408's Avatar
Yeah regular scanner connects and reads codes and such. I suspected it would be a software issue of somekind now question is how to fix it.
Old May 2, 2025 | 05:57 PM
mrvedit's Avatar
Ok, that is good!
How is your laptop connected to the OBD2 connector? Wired with USB, Wifi or Blue Tooth dongle? If dongle which one?
Old May 2, 2025 | 08:50 PM
NSFW's Avatar
What interface device are you using? Not all of them support the VPW communication protocol that gen-3 PCMs use.
Old May 3, 2025 | 08:45 PM
BReal408's Avatar
I think you mean the OBDXPRO-GT and cable to usb port on laptop. It has connected in the past and downloaded and modified bin files and reloaded them back to the PCM so it has to be something I screwed up on laptop I think. I just don't know what, because I really don't use it for much else.
Old May 4, 2025 | 12:07 PM
NSFW's Avatar
Yeah, that's what I wanted to know. That's a good one, probably the best available right now.
If there is more than one COM port available in the settings window, try using each of them. Sometimes Windows will assign a different COM port to the same device, for reasons unknown.
Old May 4, 2025 | 08:10 PM
mrvedit's Avatar
Precisely. I've seen problems like this occur with Windows updates, especially those that tighten the security to anything connected to the computer.
Old May 6, 2025 | 04:49 PM
BReal408's Avatar
Ran thru all the COM ports wired and bluetooth and still getting same error. Just figured out I am running on 4 cyl center two on pass side and inner two on drivers side. Related problem or indicator of known issue maybe?
Old May 6, 2025 | 07:31 PM
NSFW's Avatar
I just noticed that in your screenshot it says "Initializing J2534 device."
In the settings dialog box, you can toggle between J2534 or serial-port. Make sure the serial-port option is selected.
Old May 6, 2025 | 08:10 PM
BReal408's Avatar
don't know how to fix DVI error.
Old May 6, 2025 | 08:46 PM
BReal408's Avatar
Correction it is 1st and 3rd cyl on drivers side and middle two on pass side that are dead. Just broke my timing light pick up so can't tell you much more at the moment but it still runs on those other 4 cyl
