New Magnum F T56 Reverse Lockout Problem
Old Apr 11, 2026 | 02:51 AM
gjohnsonws6's Avatar
Default New Magnum F T56 Reverse Lockout Problem
Brand new Magnum F T56 will not go into reverse unless forced. Installed recently with just less than 100 miles on it so far. Goes into all gears smoothly however now it will not go into reverse without two hands, does not grind just has a lot of resistance moving to the right.
DEX 3 Fluid, Tick Master properly adjusted, Monster twin disc clutch with proper air gap, no air in system. It worked perfectly then went to go for a drive and back out of the garage with this. Sensor fuse is not blown and there is power at the connector. Any ideas?
Old Apr 11, 2026 | 06:34 AM
LS1Formulation's Avatar
It's not the trans, it's the reverse lockout solenoid. Mine was sticking and I had to push it hard to get it into reverse. I just pulled my drivetrain, so I took it out and bench tested it and it was a little sticky. I disassembled it and cleaned it, and it was functioning correctly after that. It's easy to get to on the trans, right by the shifter, only one bolt. Pull it out and bench test it. Sometimes they do fail.
Old Apr 12, 2026 | 07:17 PM
Pulled the solenoid and bench tested, confirmed correct operation. Re-installed then tested and it works perfect. Possibly an intermittent problem with that circuit.
Old Apr 12, 2026 | 08:43 PM
Rich-L79's Avatar
Did you measure for shims at the slave before you installed the new clutch? Assuming you put in a NEW slave. Bleed the slave again.
Old Apr 12, 2026 | 09:24 PM
It was measured and actually has the proper air gap without a shim. Slave is a new LUK and the system is bleed. There is a problem on the electrical side.
Old Apr 13, 2026 | 09:09 AM
Mine is having a similar problem, but it's all apart at the moment. I have a piggyback harness in my car, and the reverse lockout worked initially, but then stopped. I wonder if I'm having a similar issue to what you are.
Old Apr 13, 2026 | 09:26 AM
It was kinda weird, was testing/setting my TPS so I had the key on for a little bit then the occurrence. Who knows if that had something to do with it or it could be an intermittent problem with the system. Either a plug/pin/VSS sensor but I didn’t get that far after the bench test. Was even thinking the PCM had failed to send the ground signal.
Old Apr 13, 2026 | 10:40 AM
Kind of where I am at with it as well. I'll have to test the wiring once I get the drivetrain back in.
Old Apr 13, 2026 | 02:25 PM
speedfreak440's Avatar
This is what I did & love it.
https://lmr.com/item/LRS-7187A/mecha...id=20122150534
Old Apr 13, 2026 | 02:55 PM
Originally Posted by speedfreak440
I am afraid to run that, I’d probably be the one to grab reverse at speed and cause damage.
Old Apr 13, 2026 | 03:00 PM
I guess worst case I could put a new BP or PSI harness in. That would suck considering I just put this thing together. Hopefully this doesn’t pop up again and it was just a fluke. Curious to see what you find out.
Old Apr 13, 2026 | 03:46 PM
I was hesitant as well but curious enough to try, reverse is probably 2.5-3 times harder to push over than 5th & 6th gear, it comes with two different springs and you could go with an even stiffer one if you wanted..... nothing is impossible but it would be VERY difficult to go into reverse by mistake with this setup either way I understand the piece of mind a FULL reverse lockout brings.
Old Apr 13, 2026 | 05:10 PM
I saw those reverse lockout deletes. They're cool for what they are, but like the OP, I would not want to risk shifting into reverse at speed. I'm violent with my shifter.
Old Jun 3, 2026 | 04:39 PM
frisco88's Avatar
having the same problem with mine ,can't even get it to reverse even with 2 hands.is there fuse for this and can I get to it without removing the tranny?
Old Yesterday | 06:06 AM
I don't know if there's a fuse, but I have yet to check my circuit out to see if I have a wiring issue. I know my lockout functions correctly, but the circuit isn't providing power to it. I have a Current Performance integration harness on mine. I've been busy with a whole bunch of other crap on my car, so it'll be a bit until I can test. The unit itself is very simple to remove to bench test, if you're concerned it's not functioning.
Old Yesterday | 07:25 AM
RollingDumpster's Avatar
I recently had this same issue. Bench tested mine and it seemed "ok" but seemed like I was losing signal from the harness. I too went with the delete plug and chose the stiffer spring. Testing it with the car not running it would be pretty hard to get it into reverse while hitting 5th. The delete kit still offers resistance and the physical travel of the shifter is different enough. If i'm speed shifting into 5th, I am going way to fast.
