Catch Can fills with Oil
Old May 27, 2026 | 08:51 AM
LS1Silverado05's Avatar
Default Catch Can fills with Oil
Ok guys I need some help.
My catch can fills completely with oil in probably 20 minutes of driving. (NA 383 LS1, Heads/Cam, Intake)
I have the dirty side coming off the drivers side PCV valve.. routed to the lower port on the EliteEngineering can, and I have the top port connected to the Fast Intake behind the throttle body. Currently have one port blocked and rear port with a small breather for fresh air on passenger valve cover.
Can anyone help me account for why it’s filling like this? No significant blow by with the oil cap removed etc. It didn’t matter which way I had the lines connected at the can it fills up WAY fast.
Old May 27, 2026 | 09:51 AM
RB04Av's Avatar
Probably the valve cover. The baffles in those have been improved substantially over the years.
Replace them with the Dorman ones, which have the better baffles.
Your truck will probably run AHELLUVALOT better - especially at idle - if you do away with the "breather" and instead drill a port into the intake tube between the MAF and the throttle body, and hook the pass side port up to that instead.
Old May 27, 2026 | 08:51 PM
That would be a nice remedy! Can it really pull THAT much oil with the unrevised valvecover?
Is there another method I should consider? No catch can somehow?
Old May 27, 2026 | 10:28 PM
gjohnsonws6's Avatar
The plumbing is backwards: top port is inlet, side port to manifold. Did you just install it or is this a new problem?
Old May 28, 2026 | 12:16 PM
no, it was a mess when I got it. It didn’t even have a hose connected to the driver side. So I’m trying to get it established.
I have, however, hooked it up both ways and it fills the catch can either way
but it runs great. It doesn’t smoke unless the catch can fills up.. and if I pull the fuel cap off, there’s just very minimal vapor floats out of it
Old May 28, 2026 | 02:55 PM
Old Buzzard's Avatar
Mighty Mouse site has the correct way to hook up a can.
Old May 29, 2026 | 04:18 PM
01CamaroSSTx's Avatar
The intake manifold is doing a mighty fine job of sucking oil into the catch can. I wouldn't be surprised if some of that oil has even made its way into the manifold. I suggest that you do away with the sealed catch can, cap off the intake manifold and connect that line off the valve cover to a breather can. 3/8" hoses would be on the small side for my likes but I bet it would 100% solve your problem. I'm in agreement with changing the valve covers, especially if those are the LS1 valve covers.
Old May 29, 2026 | 04:58 PM
Here's a picture of a set of LS1 valve covers and the factory line that connects the two valve covers to the intake manifold. Biggest problem with these are is the baffling in them not to mention the size of the hole on the driver side valve cover. Being that it's at the back of the engine I can easily see the intake sucking in oil from this. I've also attached a picture of the hose connector that came off my LS1. Notice the PCV valve at the end of the line that would connect to the 3/8" hose that's on the intake manifold port? If you was going to use this type of setup with a sealed catch can like the one you have you would need to remove the little breather of the rear port of your passenger valve cover, remove PCV valve at the end of the line shown and connect that line to the top of a sealed can. Then run another line coming out of the can through an inline PCV valve that's between it and the manifold. The last thing to do would then be to run a hose from the front port of the passenger valve cover to the elbow of the air intake tube between the MAF and the TB.
Here's a picture of a set of LS3/LS7 valve covers where I removed the 3/8" ports then drilled and tapped for 3/8" NPT and installed 3/8" NPT to 10AN male bungs and connected the two valve covers to the Moroso breather can. The intake manifold and throttle body was capped off.
Hope this gave you some insight on how to resolve your issue..
Old May 30, 2026 | 11:24 AM
Thanks guys. I think I’ll try the breather can set up.
Is best I can tell even if it’s set up correctly it is absolutely pulling a massive amount of oil out of that valve cover so unless I can restrict how much vacuum it’s pulling on it it’s just gonna create a problem I
Old May 30, 2026 | 04:39 PM
wannafbody's Avatar
The Mighty Mouse can acts as a pcv valve. Most of what I get in my Mighty Mouse can is mostly a fuel and water mix with just a little oil. I have the updated Dorman valve cover on the driver's side and the stock LS1 valve cover on the paseenger side.
Old May 31, 2026 | 06:41 AM
Some cover info/background.
10-06-01-008F 1..5
