Pay to tune or buy a good programmer?
Old Dec 2, 2004 | 12:22 PM
ChevE's Avatar
Default Pay to tune or buy a good programmer?
I am wondering if its better to do a fe wmods, pay to have the car dyno tuned, rinse repeat
or
Buy a good programmer, and dial the car in as often as needed as mods come and go
Any thoughts on this?
Old Dec 2, 2004 | 03:11 PM
Bill Bowling's Avatar
Talking
If you are going to keep adding MODS I would buy HPTuner. Logging software is nice to have even if you are not needing the PCM changed. A tune can cost as much or more than the software to learn to do it yourself.
Bill
Old Dec 2, 2004 | 03:20 PM
ChevE's Avatar
Well, being a Application Developer for a living, i am leaning towards a programmer like the HPTuner setup. I did some searching, and Im sure I have much more to research. Last year when I looked into a programmer its was Predator / ls1 edit . How does everyone like HPTuner? I realize it can do ALOT, does this include everything the little powerprogrammer can do (shifting, gear ratio etc.)?
Opinions welcome in all the different programmers.
Cheers
Old Dec 2, 2004 | 03:49 PM
Talking
Cheers
A lot of people on this forum use HPTuners- they have great support and also have their own forum. There is also a new tuner from EFILive coming out in Jan. I use there logging software and it works great. They also have their own forum.
Good luck on which one you choose but make sure it is not LS1Edit. I have LS1Edit. It is not bad but their web site is the pits and they do not have very good support and no supported forum (It also cost more and does less than the other two). I am thinking of upgrading to EFILive next year. I like the idea of being able to log and edit with the same cables.
Bill
Old Dec 3, 2004 | 02:49 PM
ChevE's Avatar
Thank you for the info. I realize tools like this evolve over time. LS1 Edit was likely good for its time. I had a read over the HPTuner forum, and it is impressive. I think I am going to wait until I get my wife her LS1 (Likely a 99/00 Forumla) so I can get the two LS1's I own when I order
Anyone else have opinions regarding other tuner software?
Also has anyone written up how to make your own cable ?
Cheers
Old Dec 3, 2004 | 05:22 PM
foff667's Avatar
LS1TECH Sponsor
Cheers
well if she got an 00 formy you would still need to order another license since youve got an 00 fbody already Definitly go with hptuners im very satisfied thus far and it looks like things are only getting better...but it can me a large initial investment considering you SHOULD buy the enhanced version $660+ WB o2 $350+a decent laptop if you dont already have one $500 & up but IMO its well worth it if you plan on adding more mods at any point.
Old Dec 5, 2004 | 01:10 PM
joey_formula's Avatar
Does Anybody Use A Superchip I Just Ordered One And I Just Wanted Some Feedback On Anybody Using It.
Old Nov 8, 2024 | 02:27 PM
benisfroms's Avatar
Choosing between a dyno tune and using a handheld programmer depends on your goals, budget, and how extensively you plan to modify your car. A professional dyno tune is more precise, as it's tailored specifically to your car's setup, capturing real-time data from each mod you add, which is essential for more advanced modifications (like turbochargers or upgraded cams). While it can be expensive, it typically provides the best performance gains and optimal engine safety. On the other hand, a good programmer offers more flexibility and is ideal for ongoing minor adjustments as you add or remove mods over time. Programmers are often less precise since they rely on pre-set tunes rather than your exact setup, but they’re cost-effective and give you control over tuning without repeated dyno sessions.
Old Nov 8, 2024 | 06:44 PM
the_merv's Avatar
How does someone dig up a thread from 2004.....
Old Nov 8, 2024 | 06:58 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Not someone, but something. It's a spambot. It will probably edit this post later with some bullshit ad link like it did the other post.
edit- It appears to have a pattern of about 4 days between post and spam edit.
Old Nov 8, 2024 | 07:16 PM
That is crap.
Old Nov 8, 2024 | 10:13 PM
mrvedit's Avatar
The like spambot has been banned and this thread closed. Thank you for reporting this to me.
