Vortec 6.0L engine, harness, Megasquirt-turn key
Old Apr 13, 2005 | 10:41 PM
busta9876's Avatar
Default Vortec 6.0L engine, harness, Megasquirt-turn key
I have for sale my (i belive 2002) Vortec 6.0L LQ4 engine
Here's the Info
Vortec 6.0L block with 317 casting aluminum heads. not sure of acutal milage, i'm guessing around or less then 40k
The engine used some oil and had been disassembled when I bought it. I found that the piston rings were so carboned up they were sticking in the ring grooves, probably the cause of oil consumption. I pulled the engine apart completely and installed new sealed power rings, as well as new rod bearings. I had it apart, and only $20 i installed the new bearings.
The heads were shaved .003 and bead blasted clean. I lapped all intake and exhaust valves with the seats. after assembly I performed a compression check, 180-190 on all 8 cylinders.
I used new headgaskets, new head bolts.
With the engine includes
Starter
automatic flexplate (fits to 700r4 or th350 torque converter)
Intake manifold w/ 2003 corvette injectors (28 lbs i think, modified the fuel rails to accpet the taller injectors.)
Manual throttle body
truck accessory bracket, water pump, power steering pump, alternator, belt and tensioner. - No FAN
engine mount adaptors - to classic chevy triangle pattern.
headers - custome made from ford mustang GT shortie headers, thick LS1 flanges. may or may not work on all vehicles.
ECU : Megasquirt hardware version 2.2 running Megasquirt n EDIS software.
- custom harness for megasquirt and 6.0L.
- heated o2 sensor included
IGNITION : I DO NOT USE THE STOCK COIL NEAR PLUG coil packs
- using 4 DIS coil packs from GM 3800 or northstar engines. very common.
- ignition module : ford EDIS 8 ignition module, from early 90s lincolns w 4.6s
- crank sensor & trigger wheel - wheel mounted to harmonic ballancer, and bracket made to hold sensor.
all included
the harness is pretty much a 4 wire hookup. has its own fuses and relays built into the harness. battery, key power, ground is all to the harness. then there's a control for fuel pump.
ive been running this for about 2 months now, runs great. I have it well tuned for most driving ranges. experince in tuning, or willing to learn required. I want to sell this so i can finish my big block for my pickup. i've done a few fuel injected swaps before, you can see some on my website www.lt1swap.com i'm in southern missouri, around West Plains, 65775. I would like to sell to someone in driving distance, but would help crate it up and find a shipping method if that is not possible.
i'm asking $1800 obo for all listed. I think it is fair for time and money i have in it. i have on the website some of what i've put into the engine. all you'll need is a chevy vehicle, transmission (accepts any automatic, 700r4, th350, th400.) and a fuel system with pressure and return lines. intake has stock unmodified fuel rails with regulator on the fuel rail.
for pictures see www.lt1swap.com under the vortec 6000 section.
Old Apr 15, 2005 | 02:28 PM
busta9876's Avatar
ttt
the picture above on the left is of the actual motor i'm selling.
Old Apr 15, 2005 | 06:02 PM
camrsz's Avatar
would you consider parting out? I am very interested in the Megasquirt set up, including the ignition. Thanks PM me if you would like
Old Apr 15, 2005 | 07:59 PM
ALL UC2's Avatar
i would be intersted in the motor w/o the megasquirt set up so maybe we could work out a deal. is it a lq4 or lq9 shortblock??????
Old Apr 16, 2005 | 01:42 AM
busta9876's Avatar
i'd rather sell it as a complete package, i just started advertising it locally too and if i dont get any bites i might consider parting it out.
it is an LQ4 - dish pistons 317 aluminum heads
Old Apr 16, 2005 | 08:02 PM
busta9876's Avatar
ttt
i will consider splitting up the megasquirt from the 6.0l engine.
i have someone intersted in MS right now
make me some offers...
Old Apr 17, 2005 | 12:46 AM
69firebird's Avatar
ill buy the megasquirt from you, dont need the motor let us know
thanks
ed
firebird455@gmail.com
Old Apr 17, 2005 | 09:42 AM
smokinHawk's Avatar
if 69firebird desides against the mega squirt ill stand in line for it too.
Old Apr 17, 2005 | 12:05 PM
TAV8TR's Avatar
those heads give me some info on the 317 castings thanks?
Old Apr 17, 2005 | 08:23 PM
busta9876's Avatar
here;s all the info i have on the 317 heads
2001 up 6.0l aluminum head
used on LQ4 and LQ9 engines
210cc intake 75cc exhaust 71.06cc chambers
the 317 casting has the D shape exhaust ports. infact the intake and exhaust ports are identical to the LS6 heads, just different chamber design and size.
Old Apr 17, 2005 | 10:17 PM
69firebird's Avatar
any news on selling me the megasquirt only?? Have cash in hand
thanks
ed
Old Apr 18, 2005 | 06:16 AM
smokinHawk's Avatar
thanks
ed
Make sure you get all his spark stuff to off of it so you can help out all us other MS wanna-be's
he the only one running megaspark on an ls1.
Old Apr 18, 2005 | 04:02 PM
69firebird's Avatar
oh dont worry, if i get it im going to get it all, but I have herd nothing from him yet
speaking of which, wanna sell it to me???
Old Apr 18, 2005 | 09:56 PM
busta9876's Avatar
with such interest maybe i should build them and sell them to you all. im waiting to hear on the engine..hopefully tomorrow i'll have it sold.
i have some new pics of the coils i am using, and the headers..
website is down right now, changing servers. hopefully up in next day or two.
Old Apr 18, 2005 | 09:59 PM
69firebird's Avatar
just sent you an E-mail
Old Apr 20, 2005 | 09:58 AM
ls1_chevelle's Avatar
Wanna sell the starter? If so name a price.
-Matt
Old Apr 20, 2005 | 10:42 AM
69firebird's Avatar
or the MegaSquirt? Ive herd this guy named ED on the board would buy it from you.
thanks
ed
Old Apr 28, 2005 | 10:19 PM
custom 68's Avatar
you mentioned headers in another post. I am doing this swap in my 68 pickup and need a set. I will pm you.
thanks
DAve
