Stuff 4 Sale!!!
All prices are priced to sell.. Please no low balling but i will negotiate on some parts.. Thanks!!
First off is a pull off Acell 300+ ignition with built in rev limiter that is turn dial so it requires no chips and comes with the high out put coil.. 215.00 new from jegs and asking 100.00
2 chrome abs with new kumho 245/50/16's... less than 1000 miles on them...still have reciept if buyer wants it.. Tires $92 a peice. Asking 250.00 complete. Wheels are in PERFECT condition..
4 88-98 silverado wheels with 1000 miles on tigerpaw tires...Now owned and made by Michelin. will fit on any 5x5 pattern. Great for the trailer also! wheels are 15x8. tires and wheels are in great shape.. asking 325.00
4 used 255/60/17's Continental tires.. all are in great shape and have tons of life. One was on the front of the truck and has wear on the outside due to allignment problem.. You are stealing them All for 75.00
4 z71 wheels range from 88-2005 chevy pattern.. Has to be a 4x4 from years 88-98, and a 2 wheels drive from 99-2005 All in great condition. 150.00
sbc 23* 350 cid. 365 hp @5000 and 442 lbs/ft at 3500 rpm. World products ported heads. 2.02/1.6 valves. rocker arm studs, roller tip rockers, roller cam. .462/.470 and 210-215 duration all at .050. 9.5:1 compression.. Everything is fresh.. more to list asking 1300
i want 200 though.. they were 97.00 a piece for the tires alone which are brand new so im only charging you for tires and you are getting wheels and tires.. if you two both do 200.00 than you have a deal
