BOV, clutch, rockers, lid, T56, ram air
HKS Racing BOV $150 shipped
Only has <100 miles. HKS Racing Bypass valves are push type valves that utilize calibrated spring pressure and vacuum line pressure to remain closed against the pressurized air in the charge pipe. As the throttle is closed, creating vacuum in the line, combined with the force of the pressurized air in the charge pipe, the bypass valve pushes opens and allows the pressurized air to escape. The HKS Standard Bypass Valves are adequate for the airflow. HKS Racing Bypass Valves function similar to the Standard Bypass Valves, but incorporate an additional pressurized port to aid under severe boost conditions. The Racing Bypass Valve can also be used as a safety "pop-off" valve if the second port is connected to a pressure source that does not see vacuum. For added flexibility and function, HKS Racing Bypass Valves are offered in various adjustable boost pressure ranges that are determine by a specific spring pressure.
Yella Terra full roller rockers $325 shipped
T56 I bought from a junk yard. Came from a 02 LS1 car with 30k on it. This has been sitting my garage for a while and now I dont need it. I never installed it so I dont know how it runs. I took the rear case off and everything looks clean and I couldnt see any damage. It does not have the sensors.
$900 shipped
$900 shipped
Yeah, The only other thing it has is the rubber block off for the stock opening. It has a rain plate thats a PITA to put it, but Ill have to see if I have it.
PM coming!
PM coming!
Country boy, can I call dibs on the lid. Are the scratches very minimal? If so I want it for sure.
I have another deal working right now on one with filter for 125. I am paypal ready.
Originally Posted by Country Boy
Per forum rules, there are no dibs, so first one with cash
I hear ya! I just read that.
I think I'm gonna take the one with the filter. Thanks man. It will sell by the end of the day anyway.
what spring is in the BOV? also, is this the same one RICEETR runs?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
