Has anyone used a LS7 crank to stroke a LS1/2/6??
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Like the title says. For a 4" stroke: LS7 $713 (partsdirect), Eagle $780 (sdpc), Callies $1600 (thunder).
Does it make sense to use the LS7 crank, machine the nose and swap reluctors? Should be better quality than the eagle, but alot cheaper than callies, lunati even after machining and reluctor swap.
Thoughts?
Thoughts?
Originally Posted by Haans249
I would just run with the Eagle forged crank, its good quality, and should be just as good as the LS7 forged crank. Don't waste your money on all the extra machine work needed for the LS7 crank.
Has anybody done this?
Originally Posted by stang90gt50
Who cares if it is "better quality control" when noone has had any problems with eagle cranks. They havent broken nor is there been any machining problems.
DualQuadDave (07-25-2024)
Originally Posted by Ferocity02
Haha... Eagle cranks used to have all sorts of problems with poor machining, extremely poor balancing, counterweights that were too big, etc... They have recently cleaned up their act though and are putting out decent products. As for the original question, I think the LS7 crank would be a good choice for a stroker. I thought of doing this but I had already gotten the Eagle crank balanced. However, I'd bet that the Eagle crank can handle more power than an LS7, not much more, but more.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Don't forget the LS7 has a pretty light rotating assembly, you will most likely have to add heavy metal to it to make it balance. I haven't had to add metal with the Eagles or the Callies cranks. I have had a LS7 crank snout shortened and swapped reluctor wheels, it turned out great but if you are using a forged rotating assembly it will end being a more expensive endeavor, plus the LS7 is 4130 all the others are 4340.
That is correct, we used the stock LS7 rods and crank. These are issues to consider, most haven't done it first hand so these are the potential things you may run into, just trying to help. Dave
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
If I recall correctly when I built and up-graded my 4L60E to a 4L65E+ I bought new OEM 5-pinion planets and a new OEM Borg warner 29 tooth forward sprag and they were all made in China. I couldn't believe it but I do think that's correct.
Originally Posted by dug
Eagle equals chinese junk ![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
