Ta Fog Lights - $25
FOG LIGHTS for doing foglight upgrade.
The foglights are very solid and sealed up tight
they have a glass face that is slightly blue with 55W hyper white bulbs.
I will include all the "how to" info from the net on the fog-light upgrade
I bought them in bulk for me and a couple of guys and have 5 pair left.
MADE BY 3A RACING
EXTRA BRIGHT HID COMPARABLE PERFORMANCE DRIVING LIGHTS
HYPER WHITE SERIES
55W PERFORMS LIKE 85W
DRAMATICALLY IMPROVES VISION
EXAMPLE LINK
http://cgi.ebay.com/ebaymotors/4-3A-...QQcmdZViewItem
MADE BY 3A RACING
HYPER WHITE SERIES
EXAMPLE LINK
Abridged cliff notes version
a)Bend head of light bracket down
1-drill hole and attach bracket from new light (centered)
b)Attach positive and neg lead to wire harness via one of the following
1-cutting off plugs on wires
2-splice in wire to existing wires at base by plug
3-break off bulbs on old bulbs solder new bulb leads
to make it plug and play
I went with #3
The whole job should take 30 minutes to an hour depending on your skill level
you pull the old foglights then mod up by using the old bulbs to create plugs for the new wires it make the upgrade reversible if you ever go the notion to put the stock ones back in.
I went with #3
