Oil line restrictor poll - guys chime in
OK, I am still fighting some smoking on my setup and I think this would be good info to have for members to see what has worked and what has not.
I also want a discaimer that if you use a restrictor you run the risk of bearing failure. Per Forced Inductions it is not recommended to go below .035" restrictor. Personally, I would not go below .075".
What I would like is:
1) what turbo do you have (brand, model)
2) are you using a restrictor in the oil feed line?
3) what size restrictor?
4) what oil pressure does your engine see near redline?
5) has the restrictor cured your smoking issues?
6) lastly, if you have used a restrictor in the past and it cause problems please post up some details
7) what size oil feed line do you use?
I wouldn't go smaller than a .062 but thats me.
1) GT42, MP T70 and now TC76MPS
2)Yes
3).109, going smaller when I get my new turbo. The .109 worked great for me but I want to step it down to a .070 and see how that does.
4)60-70psi
5)Yes
6)no issues to date and I still plan to run one with the new turbo. I'll step down to a -3an feed line one of these days and see if I still need to run a restrictor or not.
J
2)Yes
4)60-70psi
5)Yes
J
1) what turbo do you have (brand, model) Master Power T70
2) are you using a restrictor in the oil feed line? Yep, actually a flange
3) what size restrictor? .060"
4) what oil pressure does your engine see near redline? 65
5) has the restrictor cured your smoking issues? Quite a bit
7) what size oil feed line do you use? -4an
I just started a thread about a smoking problem and have found it to be the oil supply line, I had to much flow to the turbo. at first I installed a .060 that helped then went to a .046 and the problem started to go away.
1) what turbo do you have- gt42 76mm
2) are you using a restrictor in the oil feed line- yes
3) what size restrictor?- started with a .060 and went to a .046
4) what oil pressure does your engine see near redline?-70psi
5) has the restrictor cured your smoking issues?- not at first then it started to clear up
6) lastly, if you have used a restrictor in the past and it cause problems please post up some details-no problems yet
could you just run a resiviour inline with the feedline? like maybe a 10oz resivour like 7 or 8 inches before the turbo. no check valve and would catch all the the oil comming down.......... or maybe not.... hmm maybe someone could elaborate on that idea...
ok guys i need some help here
i had a t-76 tti street kit before...
i just now made my own.. setup up with 6.0 manifolds yadda yadda cross ove rin the front
-10 return with a scavage pump//from what i am seeing i started it up tonight smoked a good bit idel and on it..now i didnt change anything from the tti kit as far as the turbo feed line...
im gonna build a oil resivor box for the oil to drain in first then to the scavage pump...
am i gonna need a ristrictor??
its the t76 invvate turbo they sell with there kit?
