Parting out 8-SEC motor accessories (tb, injectors, bs3, carb intake, fuel sys,etc)
ATI hub/balancer
It's 3/8" longer than stock to accomodate a 3/8" thick motorplate and still retain stock pulley alignment. You could use on a stock setup without places but you'd need to space everything else out. Or just get a new hub for $125. I paid $500 for it brand new.
Sell for $325 and I can separate hub/balancer for someone if necessary and adjust price accordingly.
T/D shaft mount rockers
1.7's everything works perfect. $900 new.
$500
Ported 241 castings currently at engine builder's shop getting examined
56cc combustion chambers I believe (will double-check).
These heads will be fresh and gone over by engine builder to make sure all valves are straight and all springs are up to spec (solid roller springs). I know they flow slightly over 300 cfm on the intake and have aftermarket valves. Obviously they worked pretty good on my setup so what else can I say?
$900
7 perfect 3.905" diamond pistons waiting to get checked
Not sure on the dish but with the above heads, the motor was 8.75:1. I think they were -22 cc's. Dart coating on top and sides. This was an off-the-shelf piston if I recall so getting the 8th should be easy...I will also have these checked over by engine builder before payment is accepted.
$150
Cam-motion spec'd solid roller cam
251/244 at 0.050 on a 114.5 lsa. Just under .700 lift both intake/exh with 1.7 rockers.
$100
Morel solid roller lifters with newish lifter trays
$475 new. Barely used.
$300
PM or Email me with offers. Buyer to pay shipping and the prices aren't firm but I don't need to give the stuff away either.
LTLHOMER@aol.com
Thanks! Selling because I need to buy a house since I'm moving for new job.
$500
$900
$150
$100
$300
LTLHOMER@aol.com
Originally Posted by skipperbisket
interested in the cam... do you have the cam card or maybe a scan of it? pm me please!!
Anything specific you are wondering about?
I will be adding stuff periodically to this as well so check back or PM me if you need something that you think I might have...
Originally Posted by 98turbls1
interested in the pistons...Do you have pics??? is it possible to get ONE from Diamond??
Originally Posted by LTLHOMER
I will snap some pics tonight or tomorrow...I believe it's possible since it's an off-the-shelf piston (I think)...I know a few local guys that work at diamond (it's actually 15 minutes from my house) so if it's possible it will get done.
Awesome man, how do the other ones look?? Any cracks or ovaling??
Originally Posted by cablebandit
can i use that tensior to replace my stock "spring" type tensioner? When i romp on it, my stock belt jumps one rib....I assume that is what your tensioner is made to prevent
