L76 Intake manifold flow results
Lift____.100”_.150”__.200”_.250”_.300”_.350”_.400” _.450”_.500”_.550”_.600”_.650”
Port 1_ 73.5_109.2_152.9_191.8_224.0_251.5_273.0_291.3_307 .9_319.7_325.6_326.0
Port 2_ 74.6_108.6_152.9_191.2_224.6_253.6_275.1_293.6_309 .4_320.1_326.6_326.6
Tested at 28” water.
4.030” test bore.
I retested the same ports with the intake bolted up. The manifold #12590124 flows as follows:
Port 1_ 73.0_107.0_148.7_182.8_211.5_235.6_253.6_267.6_278 .7_288.1_294.0_298.5
Port 2_ 74.1_107.5_148.7_181.9_210.6_234.5_253.6_266.4_276 .9_284.7_290.4_295.8
All port runners and vacuum port taps were plugged to force all airflow through the ttb flange. The manifold ports tested were driver side #1 and #5 cylinders. The intake runners tested were not at the extreme ends of the plenum.
Richard
What were you using for an ideal radius when flowing the head bare? I assume this is with the OE valve job.
Dennis
Richard
Its pretty good stock.
But even a 5% increase could be awsome.
Thanks for the test's. Great results.
Looks like we have a very top notch combo for a very good price.
4.030” test bore.
Richard
I just got them off the flow bench too. The only changes we made were cleaning up the bowl area because the stock L92's have a crappy little lip in the intake bowl area. And we added some porting to the exhaust of it too. I will post up in the morning.Rick
Port 1_ 70.4_104.5_141.5_176.0_209.9_239.8_267.3_291.0_307 .0_319.2_328.2_337.1
Port 2_ 69.9_103.9_139.2_171.4_200.4_225.8_248.5_265.6_279 .3_289.3_296.0_293.5
__________________________________________________ __________________________
Richard
The test was done on a Superflow 600 with flowcom. I also retested on my JKM and saw within a 1% difference as usual.
Richard
Just comparing sf600 to sf1020 always seems to be different although with results backing up with the JKM suggest that the sf1020 is somewhat different in its measuring there always seems to be some disparity between those 2 benchs
thanx for the info though. Look like the intake works alot better then the ls6 peice at least
................. The end result is the bench now mirrors a typical SF600. I've tested it with several in the area with very similar results. I've heard a number of SF1020 owners make similar statements to yours about the flow differences to other benches. Next week I'll be testing our new All Pro LSW head and will have the opportunity to compare the test head on a SF1020 while using the same fixturing. This should make an excellent apples to apples comparison. Richard
Sorry Rick. I wasn't sure if anyone else was persuing this info and since it's part of our development, I thought it would be of some interest here. My test head has no work. I felt it would be a better baseline for comparing against the other combinations, but I'm interested to see how your results compare.
Richard
Maybe you found the same thing, but the bowl work needed big help in the intake seat area. After this, I think we ended up in the area of 328ish with the manifold bolted on. Nice really. The exhaust is where I told my porter to spend time on. 230's without a pipe is where we landed.
Rick
