MSD fuel voltage booster
Old Nov 11, 2006 | 12:59 AM
SleeperZzZ28's Avatar
Default **** MSD fuel pump voltage booster ****
Got this with a kit but I decided to go a different route. My loss is your gain. $150 shipped. These retail for over $200
Old Nov 11, 2006 | 01:10 AM
heres the item description right off the MSD's website
Fuel Pump Booster
Adding a turbo or supercharger to your engine is a great way to improve the power of your car. But you have to remember that when more air is being pushed into the engine, the need for additional fuel raises proportionally. Meeting these new fuel demands could mean larger injectors or ECU programming, both which can be pricey. This new Fuel Pump Booster is the economical (and easy) answer for your engine’s new fuel demands.
The Booster will supply the electric fuel pump with increased voltage in relation to the manifold boost pressure. As boost pressure increases in the manifold, the MSD Booster will increase the voltage to the electric fuel pump. The amount of voltage is adjustable with a potentiometer from a range of an additional 1.5 volts to a maximum output of 22 volts over a range of 5 – 30 psia.
Old Nov 11, 2006 | 04:57 AM
cablebandit's Avatar
that is a great price and would work awesome for anyone needing to get a tick more out of a single walbro.
Old Nov 11, 2006 | 12:07 PM
Up to the top for the day.
Old Nov 11, 2006 | 07:23 PM
up again
Old Nov 12, 2006 | 05:09 AM
Its 335 on MSD's website
http://www.shopatron.com/product/pro...=MSD2350/424.0
Old Nov 12, 2006 | 07:04 AM
ZUBIKZ06's Avatar
Default MSD Fuel Booster
PM Sent
Old Nov 12, 2006 | 08:42 AM
paydfour's Avatar
i have a stock zz4 crate lt-1 with avortech supercharger you think this would help me a lot i am only running 4.5 psi
Old Nov 12, 2006 | 04:54 PM
pms replied
back up
Old Nov 13, 2006 | 03:15 PM
T T T
Old Nov 14, 2006 | 06:03 AM
UP again
