Car sold...leftover parts for sale!! make them go away
Well I sold the camaro, so time to clean out the garage finally. Local pickup is preferred. I will help with delivery if reasonable distance. I live near the Woodlands, just north of houston.
First come first serve.
Here is what I have....
- NEW Stock LS1 cam from 2001 engine. Never ran in engine, cam was taken out prior to install. I used a bigger cam. $35
- Stock air lid, w/ baffle box, and tubes from 98 camaro $10
- Stock drive shaft loop from 98 camaro 6 speed $10
- NEW stock thermostat from 98 Camaro $10
- MAF with ported housing, no fin....(unsure on application...part # on bottom is 89872172501) >>>>SOLD<<<<
- Seatbelt pieces x 2 $5
- shifter ****, black leather $5
- NEW clutch bearing in bag, and slave cylinder >>>SOLD<<<
- NEW Stock pushrods (16), and new valve seals (I only have 15 valveseals) $20 <<PENDING PICK UP>>>
- used pushrods, rockers and bolts from 98 LS1 (complete set) <<<SOLD>>>
- NEW stock valve springs, retainers, and clips (complete set) >>>SOLD<<<
- NEW in box Manley 221423-16 valve springs for stock head applications (set of 16)(i think they are ~140 new) <<<SOLD>>> $100
- Misc. bolts from 98 LS1 <<<SOLD>>>
- Guage for adjustable torque arm $whatever
- 13 quarts Castrol GTX SAE 20W-50 (one is 1/2 empty) <<<SOLD>>>
- I also have the stock manifolds $make offer-no pics
- stock susp. parts (torque arm, panhard bar, lower control arms) $make offer-no pics
IF SOMEONE WANTS EVERYTHING, You CAN HAVE IT ALL FOR $100...But you have to take it all.
