Can you build 427 c.i. using an iron 6.0L block?
Texas Speed lists a 4.100 Eagle crank at the same price as a 4.000, $900. Combine that with a 4.060 LQ9 block and you get 424.6. Close enough? The disadavantage is that I believe you'll need to spring for custom pistons, so that's a few hundred extra.
The 4.00" stroke appears to be very popular with LSx engines, the larger strokes much less so. I suspect there are good reasons for this having to do with block deck height, compression distance, etc.
Texas Speed does a 418 4.080x4 L92 shortblock for $4755. Katech has their value 4.125x4 sleeved 427s for a bit under $7k. I doubt it can be done much, if any, cheaper than either of these packages. You might call TSP and ask about a L92 block with the Eagle 4.1 crank and custom pistons for 429cid. I'm going to guess at around $5200. If you do, please post results; I'm interested myself.
it sucks that cheap, reliable, and fast cant all go together
there is no such thing as a 6 liter block because the liters consist of bore and stroke, so the block can be any liter with in that range, a few over or under .. but only a few like 6.3 or 5.8 liters ..
GM can do this because except for the 4.8 and LS7, all LS engines use the same stroke crank.
