L92 head and intake swap
Old Mar 2, 2007 | 12:56 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Default L92 head and intake swap
I just swapped some L92 heads and I also bought the bare intake so I can just swap my fuel rail, TB and injectors over to the new intake.
I have a small issue(s).
- The stock LS2 fuel rail cross over tube sits a lot higher on the new intake than on the LS2 intake manifold. Is this normal?
- Also, I have some typical 42lb Bosch, Lucas, etc injectors that I'm going to use and the O-ring seems a little loose in the L92 intake manifold bore.
Is there a larger/fatter O-ring or fix for this?
Thanks in advance,
allen
Old Mar 2, 2007 | 01:01 PM
WKMCD's Avatar
Thanks in advance,
allen
The 42lb injectors are taller than the LS2 stock injectors. That's what's making the fuel rail sit so hit. It doesn't hurt anything. You'll need to get the o-rings from K-tech to make the 42's fit more snugly.
Old Mar 2, 2007 | 02:59 PM
FarmTruc's Avatar
Ya, they are taller, but the LS2 fuel rail doesn't fit exactly like it's supposed to. It obviously fits perfect on the LS2 intake, but put it on the L76 intake and the injectors are positioned wider than the injectors bosses in the intake manifold, plus, the old spacers I used on the LS2 intake manifold are tooo short, so the LS2 fuel rail does sit higher on the L76 intake manifold.
Also, Katech has an adapter kit for LS1 to LS2 conversion, they didn't have anything for the LS2 to L76 manifold swap using Lucas 42lb injectors (very common).
Any help is very appreciated,
Once again, I need a fatter O-ring for the injectors I had on the LS2 manifold and I guess the LS2 fuel rail isn't going to work. I can tell the injectors are kind of off when you force them into the injector L76 intake bosses.
thanks again,
allen
Old Mar 2, 2007 | 03:43 PM
See5's Avatar
[QUOTE=
thanks again,
allen[/QUOTE]
Ok, what you see below works swell (we have done 2). Using a LS1 rail cut cut out the crossover and slightly bend tabs to fit and using spacers (made from tubing). The fat o-rings are available from Lingenfelter.
This maybe too cheesey but it fits and works great.
Old Mar 2, 2007 | 03:49 PM
WKMCD's Avatar
thanks again,
allen
I got my fatter o-rings from K-tech.
Old Mar 2, 2007 | 03:52 PM
WKMCD's Avatar
I did this originally but the clamps kept loosening. I went with a FAST setup.
Old Mar 2, 2007 | 04:00 PM
See5's Avatar
That is the decidedly, non cheesy approach.
Old Mar 2, 2007 | 04:41 PM
2c5s's Avatar
Katech's LS7 spacer worked on mine. The LS2 kit's spacers were the wrong height. SDPC has the orings and spacers also.
 Michael S. Palmer
Old Mar 6, 2007 | 08:43 AM
FarmTruc's Avatar
Well I got some fatter injectors from Ling.
I called SD for a new fuel rail that will fit the L76 intake, and they said it was just an LS2 fuel rail, which isn't right. Hopefully they'll come up with something and I won't have to cut the crossover tube.
thanks for the reply guys!
allen
Old Mar 6, 2007 | 08:41 PM
98blackSS's Avatar
You got em from who?
Old Mar 7, 2007 | 09:39 PM
CamaroSS22's Avatar
what are u guys using to mount the throttle cable to the side of the intake on an older gto and on the f-body. my l76/l92 combo should be in soon and it didnt even cross my mind on how that was going to work.
Old Mar 17, 2007 | 05:55 PM
Phate's Avatar
I just went through the same thing. I dropped the rails off at a shop on Friday and pick it up monday. They are going to braze -8 fittings onto each side of the x-over tube on the rails and then use -8 braided line to bridge it...should look nice
Old Mar 18, 2007 | 04:21 AM
Yellowsierra's Avatar
Whats up Allen! Are these heads going on your GTO?
