Synergy Twin dyno results....two dynos
Old 04-19-2007, 02:25 PM
Rick@Synergy's Avatar
Default Synergy Twin dyno results....two dynos
Ok, so I was able to get results from my dyno and a Dynojet which is what everyone likes to see. So here are the two graphs, same car, same day pretty much. On my dyno, I can apply alot more load to the car, so the car wound up making almost a full 1.5psi more than when I got on the dynojet. Which is about what I expected it to do. I also found I could squeeze more timing into the dynojet graph, but once I hit the street, I had to take it right back out. The Ic temps where not quite as good as they were on the street, but this should give an idea of what the car made so far. Now start the questions.
Rick
Old 04-19-2007, 05:25 PM
Bad30th's Avatar
Niiiiiiice !!
Rob (Bad30th)
Old 04-19-2007, 05:48 PM
Blackbird's Avatar
interesting for folks to take note.
due to load the car makes more boost aka more power on the street thus that tune joe blow gets on the local dynojet (unless they have the brake loading capability) is gonna be quite on the edge once you hit the road.
figure add the hp and tq another 1.5psi of boost makes to the dynojet graphs and they jive right up with the dynopack.
good stuff, wish I coulda make it up there for a test drive
so the next logical question for the GTO owners out there is how much and when can they ship!
Old 04-19-2007, 08:51 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Damn Rick the twins are making some good power. Wish my torque graph looked that good.
Old 04-20-2007, 09:13 AM
RealQuick's Avatar
What were the dtails of this setup again?
Old 04-20-2007, 09:24 AM
Ferocity02's Avatar
Was this the GTO? Awesome results Rick!
Old 04-20-2007, 09:38 AM
Heads and mild camshaft, about 9-10 psi of boost and our twin kit.
Rick
Old 04-20-2007, 09:39 AM
Yes, thats what concerned me as well with the load thing.
I am hoping to put this kit around 5500-6K when done.
Rick
Old 04-20-2007, 10:17 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Is that A/F correct on the dynojet graph? If so, thats way rich isn't it?
Very nice numbers!
Old 04-20-2007, 10:19 AM
Very nice numbers!
No AFR was taken on the dynojet because I did no tuning on the dyno with the car. I had all the Wideband stuff in my laptop.
Rick
Old 04-20-2007, 10:26 AM
obZidian's Avatar
could that line be boost?
Old 04-20-2007, 10:49 AM
No, no meassurements where taken on the dynojet, just numbers. I had everything on my laptop.
rick
Old 04-20-2007, 12:03 PM
99Z28LS1's Avatar
looks good rick, congrats
Old 04-20-2007, 12:21 PM
RooRnZ28's Avatar
nice!! so is there an fbody kit out as well?
Old 04-20-2007, 04:35 PM
stevieturbo's Avatar
Odd....Id have though the Dynapack would read a lot lower than the Dynojet numbers, even more so if the Dynojet might be making less boost ??
Old 04-20-2007, 06:45 PM
working on it now, should be done soon.
Rick
Old 04-20-2007, 06:47 PM
Its different all the time. Its like when you see mustang dynos read different all over the place. Why do some read like dynojets and vise versa. The Dynapack cant be changed, there are no variables, and it meassures TQ, not estimated HP. So those are the differences.
Rick
Old 08-11-2007, 09:52 AM
Yogi Bear's Avatar
Rick
All dynos measure torque only. HP is always calculated from a formula based on torque and RPM. The dyno displays HP because it is doing the calculation for you using the torque and RPM numbers.
Old 08-11-2007, 10:13 AM
Not true. The dynojet does not meassure TQ.
Rick
Old 08-11-2007, 10:22 AM
Yogi Bear's Avatar
Rick
It HAS to measure torque. That's the only way to get HP. There is no instrument or machine that can "measure" HP. HP is calculated based on torque and RPM.
Quick Reply: Synergy Twin dyno results....two dynos
