APS GTO twin turbo system - $5995 inc free delivery and free set of 60 lb injectors
Old 07-31-2007, 08:01 PM
peter@aps's Avatar
Default APS GTO twin turbo system - $5995 inc free delivery and free set of 60 lb injectors
Hi Guys, I've been working on putting together a deal for you guys for the new GTO intercooled twin turbo system. I have 10 GTO intercooled twin turbo systems ready for despatch at the end of August for just $5995 including a free set of 60 lb per hour fuel injectors and free door to door delivery, be quick to get into this awesome APS GTO twin turbo deal, it's the last deal for the 07 year.
The twin turbo system can be browsed on the APS web site on the link below.
http://www.airpowersystems.com.au/ls1/us_gto.htm
A brief summary of the twin turbo system, designed and manufactured for the US spec GTO,
1) Cast ductile iron turbo exhaust manifolds.
2) Twin liquid cooled 500 HP inconel spec precision gasoline turbochargers.
3) Massive air to air bar and plate intercooler.
4) Stainless steel ducting with perfectly balanced air flow to and from each turbocharger.
5 Twin Stainless steel air inlet ducts with high flow air cleaners.
6) Twin 3 inch 304 stainless steel turbo down pipes with mounting provision for Tial 38 mm wastegates.
7) Twin 38 mm Tial wastegates.
8) APS billet alloy dual vent blow off valve.
9) Tough and durable nomex reinforced silicon coupling hoses.
10) High quality stainless steel studs and all nuts, washers, bolts and brackets required for the install.
View the comprehensive list of components at the link below,
http://www.airpowersystems.com/gto/install/bom.htm
All you need to add is your own fuel pump or boost a pump (because this package does not include any fuel pump). A set of 60 lb injectors and a Walbro 255 LPH fuel pump will support around 520 whp.
For the guys who are planning on going to higher power levels may chose to fit the APS twin pump fuel system, see link below.
http://www.airpowersystems.com/gto/f...sgto-fss06.htm
This special APS offer includes direct door to door air freight to any destination within the 48 mainland states of America. The $5995 price includes free door to door delivery anywhere within the 48 mainland states of the US.
This special APS direct offer is available to the first 10 members only - so get in quick.
Payment: Visa and Mastercard credit cards will be accepted and the entire transaction will be in US dollars (therefore the currency exchange rate between Australian and US dollars won't impact on you guys). I will require a deposit of $1000 now to confirm your purchase intent and then the balance of $4995 prior to despatch from APS which will late August 07.
The delivery time is between 3 to 5 days from despatch, how's that for awesome speed!
Feel free to contact me via PM or email (peter@airpowersystems.com.au).
Thanks,
Peter
Old 08-01-2007, 05:12 PM
BLKWS6's Avatar
Dang...too bad the Fbody kit didnt come with the injectors....
Quick Reply: APS GTO twin turbo system - $5995 inc free delivery and free set of 60 lb injectors
