HOHOHO HS Rockers,CC lifters,cc timing,36# SVO and much more!
Old Dec 14, 2007 | 10:44 PM
madmaxz's Avatar
Default MORE STUFF! HS Rockers,CC lifters,cc timing,36# SVO and much more!
I have a bunch of ls1 suff forsale from my last project.
PRO 5.0 SHIFTER - $150
AVAILABLE PRC LS6 CNC Ported Heads, 2.00 1.55 Valves , comp valve job, LS6 springs USED 200miles - $900
-SOLD- Harland sharp rebuild stock rockers NEW - $250
Compcams adjustable timing set NEW - $200
Compcams stock 850 lifters NEW - $180
-SOLD- used 30# injectors - $150
texas speed Hiflo Oil pump - $120
-SOLD- NGK tr6 plugs - $10
ARP Pro Series Wave-Loc Rod Bolts 234-6301 - $100
texas speed 7.3 chromemoly pushrods - $100
-SOLD- Forged Wiesco pistons for stock bore USED very good condition - $300\
hypertech power stat - $40
20-12560696 GM LS1 Valve Cover Gasket, 1999 and up (2 required) $17.99 - $35
20-12533587 GM LS1 Intake Manifold Gasket Set $60
20-12588372 GM LS1 Water Pump Gasket, 1999 and up (2 required) - $6
20-12498545 GM LS1 Head Bolt Kit for single cylinder head, contains 5 M8 bolts, 2 short head bolts, and 8 long head bolts. - $27
20-12617944 GM LS1/LS2 Exhaust Manifold Gasket (2 required) - $24
-SOLD- 20-12574293 GM LS1 Rear Cover Gasket $20
-SOLD- 20-12574294 GM LS1 Front Cover Gasket $20
-SOLD- 20-12585673 GM LS1 Front Main Seal $17
-SOLD- 20-89060436 GM LS1 Rear Main Seal $17
-SOLD- 20-12557840 GM LS1 Crankshaft (Harmonic Balancer) Bolt $4
PISTONS:
SLP Weldin Subframe connectors - Black powdercoated- NEW - $275
Old Dec 15, 2007 | 11:43 AM
madmaxz's Avatar
bumppppp
Old Dec 15, 2007 | 12:04 PM
homerunhtr21's Avatar
location? anything wrong with the injectors? You have any feedback anywhere?
Old Dec 15, 2007 | 12:18 PM
madmaxz's Avatar
injectors work perfect, im in baltimore MD, ive been a member here since 05 and sold a lots of stuff, as well as on camaroz28.com, tacomaterritory.com, and easternfbody.com
Old Dec 15, 2007 | 12:22 PM
Brian2006's Avatar
Plugs new or used?
Old Dec 15, 2007 | 12:51 PM
madmaxz's Avatar
plugs are sold
Old Dec 15, 2007 | 02:30 PM
madmaxz's Avatar
more stuff!
Old Dec 15, 2007 | 03:30 PM
johnLs1camaro's Avatar
prices include shipping???????
Old Dec 15, 2007 | 03:48 PM
ufsnola's Avatar
pm sent
Old Dec 15, 2007 | 04:01 PM
madmaxz's Avatar
in most cases yes prices are shipped.
Old Dec 15, 2007 | 04:16 PM
RE AND CHERYL's Avatar
Are the injectors 30lb or 36 lb. Your thread title and the list above are different.
Re'
Old Dec 15, 2007 | 04:28 PM
madmaxz's Avatar
yeah their 30# svo's
Old Dec 16, 2007 | 06:18 PM
madmaxz's Avatar
bumpppp
Old Dec 16, 2007 | 07:25 PM
Steve01SS's Avatar
Are those Wiseco pistons for press fit pins or spirolox. Stock pin bore? or .927?
Thanks.
Old Dec 16, 2007 | 08:03 PM
madmaxz's Avatar
im not really sure, im guessing press fit and stock bore because of the stock rods they were used with?
Old Dec 16, 2007 | 08:19 PM
Steve01SS's Avatar
I just cant see in the picture where the pin is if there is a small snap ring or not.. Or if there is a groove for one?
Old Dec 16, 2007 | 09:42 PM
madmaxz's Avatar
i do see what looks like a groove for a snap ring on both sides.
Old Dec 17, 2007 | 03:17 PM
madmaxz's Avatar
bumpppp
Old Dec 20, 2007 | 08:31 AM
madmaxz's Avatar
ttttt
Old Dec 20, 2007 | 08:39 AM
badazz99ta's Avatar
i need the pro 5.0, but i wont know if ill have the money for another week or so. but as soon as i know i will let u know. good luck with all the sales.
