non-LSX Parts For Sale SBC, LT1, V6, etc.
parting out several 4th gen f-body's
Old Jul 3, 2008 | 07:32 PM
STS95T/A's Avatar
Default parting out several 4th gen f-body's
94 Complete LT1 with all accessories and wiring and PCM 87k miles-$1200
94 Complete LT1 with all accessories and wiring and PCM 103k miles-$1000
Complete T5 Conversion for 3800 series V6 Camaro or Firebird-$400
94 LT1 A4 tranny-$250
Catco catalytic converter-$40
LS1 dual fan assembly-$80
93-97 V6 radiator-$40
LT1 dual fan assembly-$80
Salad shooter center caps-$5 each
LT1 fuse cover (under hood)-$10
LT1 PCM bracket-$10
93-97 Firebird headlight control module-$25
93-96 Camaro HVAC controls-$20
93-96 headlight control panel-$15
Dual horn assembly-$20
Hatch release button-$5
Mirror bolt cover triangular trim pieces-$5 each
Dark gray cigarette lighter-$5
Grey seatbelt loops-$5 each
Black Camaro power side mirrors-$25each
93-96 Camaro 110mph gauge cluster w/ 124k-$25
93-96 Camaro 150mph gauge cluster with 147k, 304k, and 113k-$35 each
Leather e brake handle assembly-$20
Camaro key fob-$10
A4 pedal assembly-$35
Firebird tail light center section-$20
LT1 heater hoses-$30
M6 steel driveshaft-$40
New spare tire-$25
Complete 342 rear end-$300
93-96 Camaro drivers air bag-$40
95-02 Firebird/trans am driver’s air bag in grey-$40
Complete steering column minus steering wheel and air bag for 93-02 f-body with key-$75
LT1 valve covers-$30 pair
LT1 timing chain-$20
LT1 cam timing gear-$10
LT1 spider (lifter support)-$15
93-97 Firebird passenger complete headlight assembly with motor-$80
LT1 brake booster-$15
LT1 steering rack-$40
LT1 k-member with a- arms-$40 pickup only
LT1 e brake cables-$40
LS1 e brake cables-$40
643 casting LT1 aluminum heads-$200 pair
LT1 oil pump and pick up-$20
93-97 right hand f-body air bag-$30
93-02 right hand f-body air bag-$30
LT1 f-body accessory bracket-$30
LT1 A4 shifting linkage with all cables and sensors-$40
93-96 Camaro dash (not upper dash pad)-$60
93-97 Camaro complete headlight bar-$80
Descreened LT1 MAF-$30
RH tinted t-top-$100
A4 steel driveshaft-$30
3 channel non traction control rear axle-$25
93-95 air bag sensor set (3)-$20
93-97 M6 stock pedal assembly with all sensors-$50
93-97 M6 pedal assembly with all sensors and Z28 decal on pedals-$60
Coolant reservoir with good battery tray-$25
93-95 Firebird/Trans Am dash (not upper dash pad)-$80
T-top brackets (set of 4)-$15
T-top divider (mounts on roof)-$20
Rear view mirror-$15
Dome light in gray or tan-$5
LT1 radiator support shroud-$25
Complete stock jack assembly with cover-$25
Complete 323 rear end-$250
Right and left complete LT1 front spindle assemblies-$30 each
Stock PHB-$20
Stock torque arm-$20
Stock brake master cylinder-$15
93-96 A4 Camaro shift plate-$30
94-97 LT1 stock intake manifold-$75
LT1 stock throttle body with all sensors-$25
Firebird headlight control-$20
Firebird HVAC control panel-$25
Firebird window, mirror and lock controls-$40 both sides
Camaro window, mirror and lock controls-$30 both sides
V6 rear end complete with drum brakes-$60 pick up only
White Firebird hatch-$40 pick up only
Red Firebird hatch-$40 pick up only
Red Camaro z28 hatch-$40 pick up only
Black Camaro z28 hatch-$40 pick up only
Camaro front fenders in silver, blue and green (needs paint)-$25 each
Maroon Camaro manual doors with door panels-$100 pair pick up only
94-97 LT1 fuel rails-$40
93-95 LT1 stock single cat y-pipe-$20 pick up only
Stock LCAs-$20 pair
Stock a-arms-$15 each
LT1 A4 starter ring-$25
Red Firebird rear bumper (needs paint)-$40 pick up only
Maroon Camaro front bumper (needs paint)-40 pick up only
LT1 A4 dust cover-$20
Aftermarket tranny coolers one measures 9x7.5x3/4-$20 and the other measures 12x10x3/4-$40
LT1 thick core radiator-$80
98-02 v6 radiator-$40
Red Camaro rear bumper (needs paint)-$40 pick up only
Good battery-$10 pick up only
94-97 LT1 fuel lines-$25 set
93 LT1 fuel lines-$25 set
Camaro tail light wiring harness-$20
Firebird tail light wiring harness-$20
I also have a complete LT1 parts motor that I will be parting out next week, if you need anything please PM me.
My paypal is f-bodyparts@hotmail.com
I’m located in Mansfield tx 76063
all prices are obo and without shipping
robbie
Old Jul 3, 2008 | 08:38 PM
TheDon619's Avatar
how much for sun visors for a 95 firebird formula and the 2 rubber peices ont he front and back o the t bar
Old Jul 3, 2008 | 09:25 PM
STS95T/A's Avatar
sorry but i do not have either in good condition
thanks
robbie
Old Jul 4, 2008 | 12:40 PM
ctx97's Avatar
35$ shipped? Have paypal ready,
thanks
Old Jul 4, 2008 | 01:21 PM
blazin's Avatar
93-96 Lt1 M6 shift plate
Old Jul 5, 2008 | 04:31 PM
snk-huntr's Avatar
Would you happen to have a stock water pump for an lt1?
Old Jul 6, 2008 | 12:51 AM
XLR8myV6's Avatar
I'm doing V6 auto to manual swap. Need t5 bellhousing for 97 camaro, master cyl. assy., flywheel. PM me or if I don't hear from you by later today 7-6, I'll PM you. At the very least I need master assy.
Old Jul 6, 2008 | 12:57 AM
yogibear19's Avatar
Do you have pics of the 150 MPH speedos? Could you send them to me at Yogi_Bear_19@***.net. Thanks.
Old Jul 6, 2008 | 11:44 AM
STS95T/A's Avatar
the shift plate, and the h2o pumps are sold
pm's sent on everything else
thanks
robbie
Old Jul 6, 2008 | 09:27 PM
indirocz28's Avatar
Im looking for a GOOD WORKING fuel sending unit Price & shipping to 47591 please,
please PM
Old Jul 8, 2008 | 09:29 PM
HavinSomeFun's Avatar
I need the red and yellow side lens covers for a 93 firebird. Previous owner painted them black..... shipping to 72022?
Old Jul 8, 2008 | 09:52 PM
McCauleyWB's Avatar
Happen to have the trim pieces on the interior of the side mirrors (triangular shape), specifically driver's side? Also, the front seat bolt covers?
Shipping to 90650. Thanks.
Old Jul 8, 2008 | 10:16 PM
Airplanedoc's Avatar
Where are you located?
Old Jul 15, 2008 | 09:35 PM
gearhead6s's Avatar
Is the rack complete from rod end to rod end? price shipped to 40299?
Old Jul 15, 2008 | 09:44 PM
McCauleyWB's Avatar
Still looking for the front seat bolt covers, in addition to a Camaro tail panel if you have one in good shape.
Old Jul 16, 2008 | 01:50 AM
01Farburd's Avatar
I'm interested in the 98-02 V6 radiator if it's for an automatic. How much shipped to VA 24277? Thanks. Tim
Old Jul 16, 2008 | 03:53 AM
GOR1LA's Avatar
wouldn't happen to have a complete interior in black for a 4th gen would ya?
Old Jul 17, 2008 | 11:48 PM
orangeappeal02's Avatar
***Scammer Alert!!!***
Do you have the headlamp mounting panel for the 93-97 trans am
Old Jul 18, 2008 | 01:42 AM
I_Need_Land's Avatar
interested in the 3:42 rear end.
pm me info
Old Jul 18, 2008 | 06:56 AM
Ttypeterror's Avatar
I need an optispark. Do you have one?
