Performance parts: Warriors, Y-pipe, 9" Auburn Posi, NX kit ect...
First off I have a set of Warriors for sale 15x3's up front, and 15x10's out back. The backspacing is 6.5" on the back. They do barely stick out on the back, but its not bad at all. This same set-up was on a stock width rear end and cleared fine(with the 275/60(28") Nittos). The fronts tires are still good, but are a little more than half worn. The back tires are not mounted but will be before shipped, and they are a little less than half tread. But was still cutting 1.6x 60's. Would like to get $700 shipped out of these.
Also have a TSP y-pipe with a LoudMouth 2 muffler bolted up, and SLP quad tips. You would have to get a muffler shop bend a piece of pipe to go over the rear end to connect the two. There is a bung already welded on the y-pipe for a wideband, but does come with a bolt to close it off when not in use. Would like to get $225 shipped.
Here is a Auburn Posi unit for a 9" with 31 spline axles. Worked fine on the street, but would spin one tire at the strip if both tires werent heated the same. Guessing it needs a rebuild. Would like to get $250 shipped.
Also have a NX express single nozzle wet kit. Comes with dual gauge pod, bottle heater, bottle pressure gauge, MSD window swith(3k-6k pills). Would like to get $525 shipped.
hence the reason i asked about the rear wheels only.
which backspacing does your fronts have? 1 7/8 or the 2.25?
