Signature Testing & Design Test your sigs here!
Test archive
Old Oct 31, 2014 | 06:10 PM
GARY2004Z06's Avatar
Default Test archive
The stalker speaks.
Originally Posted by firehawk 385
You already went 9.97 @ 137 in the past (2011) https://ls1tech.com/forums/single-di...137-72mph.html
Running 9.97 @ 137 again in 2013? Am I missing the point of this thread?
It's a c5 ZO6 with roughly 2700# raceweight. LS6 NOT and LS1 and it has a big stuff 3 computer with 8 egt's in the pipes.
Maybe it's time you let go of his shirt tail and stop using his accomplishments and find some of your own.
Show me where YOUR 9.32 @ 148 is here.....
https://ls1tech.com/forums/drag-raci...-n-any-cu.html
Destroked LS7 with a restricted stock computer and another motor for this spring sounds Incredibly familiar with someone elses car.
Complete coincidece right?
I doubt it's excuses. More like your lies and B/S.
Better air? Since when does air quality effect E85 the same as a gasoline burning engine?
You are B/S from your 1st word to your last.
no you don't
Only in your fantasy do you fit this thread
That would be a NO
I gaurantee you picked up 20-30 RWHP with your 8 widebands and cyclinder to cylinder tuning from your Big Stuff 3 that you don't like.
You don't have a legit LS6 "Cam Only" engine.
No LS6 came with valve reliefs.
No LS6 came with hardened rod bolts.
Are the valves and valve job stock the way GM sent those heads down the assembly line?
A legit "Cam Only" has just a cam/spring change and typical external bolt ons. Tuned on stock PCM and runs on gasoline
Nothing more.
The car you're questioning doesn't have a stock LS6 cam and also isn't following the "Cam Only" format.
He wants you to believe his car ran "Cam Only."
Of course with an untouched LS6 long block, untouched LS6 heads with stock valves, stock valve job, stock computer, no cylinder to cylinder tuning, stock M6 without being faceplated, "gasoline", stock unmachined pistons, stock rod bolts, etc.....
"Cam Only"
Old Oct 31, 2014 | 06:34 PM
Interesting.
Originally Posted by Firehawk441
http://tunetimeperformance.com/.............Lakewood, N.J.
http://powerhaus-performance.com/.........Cherry Hill, N.J.
It was my pleasure working with you and Chris on this project.
Big time congrats.
Air intake to the engine.
They are Hoosier 30 x 10.5 Radial slicks.
The shortblock is 100% stock with Stock Rod Bolts and NO valve reliefs in the pistons.
Heads are untouched 241's with the exception of valve springs.
Head gaskets are stock multi layer.
Cam is an out of the box T-Rex
Fast 90 intake
1 7/8 headers
Custom y-pipe and single muffler
Under drive crank pulley
Electric waterpump
OEM alternator
Tuned by SSPerformance
TH350 trans with a break
8" converter
12 bolt w/4.33 gears
Basic suspension parts that everyone else uses
100 octane unleaded...
I totally agree with you John.
Too many try to munipulate what "CAM ONLY" stands for.
Yes it is...
YUP.
Machine work is a modification.
This car ran the number without any...
Making a "STICKY" would be a good idea. There has always been ALOT of interset in this "RECORD".
I would think that since Chris and Charlie hold this internet record, using there car as a guideline would be a good start. Now when others are chasing this "Record", they will all know what it took to run the 9.98 and what deviations to there own cars they have, If any, in the attempt of claiming the title.
Word it any way you can think of....Cut pistons still aren't stock.
Thank you for saying "MODIFIED". Now it's no longer stock.
I might possibly know that the modified piston by itself won't make more power. Only the clueless would cut the piston, lower the static compression for a cam profile that doesn't need the room.
The material removed from the pistons for these valve reliefs will however make the pistons lighter. This will have different effects that I'm not getting into here.
The larger camshaft that will now fit because of these modified pistons WILL make more power.
That's very good with these lower power levels. Nice job.
No it isn't...
Now that's funny.
Casing an Internet record that a young kid set that didn't have enough money for a REAL engine. Have fun with that.
Don't say YOU ALL.
I respect your efforts to make piece and I welcome it.
Your friend however has made every effort to infect this thread. Not participate.
This car ran 9.98 with a GM piston that wasn't cut.
I took some time to search out this company after reading their "going out of business thread" and stumbled across this thread.
These douschebags talked all kinds of crap in this thread and fell Over 3 tenths short of this record.....
Now it's apparent that they ripped quite a few people off AND they can't back up their trash talking.
Hopefully in the future people search out ALL posts from Advertisers and NOT just threads they're selling themselves in.
Just reading how they conduct themselves in this thread would've shown how unprofessional they were.
Although I have to laugh at their failures, I feel for those effected financially from them.
BTW....I never realized someone had gone this quick "Cam Only" with an LS1 and that nobody has even come close to challenging it in the past 2 years.
Nice job to the OP and those involved.
They failed at the record.
They failed as a business.
I wish the best for those that were deceived by them.
Old Oct 31, 2014 | 06:36 PM
More.
Production style tranny and rear.
Any Automatic and probably Manuals are limited to only an M6.
Old Nov 2, 2014 | 08:47 AM
01ssreda4's Avatar
What is all this non-sense?? Its like reality TV around car guys sometimes!
Old Nov 2, 2014 | 12:29 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
No idea why this is posted here nor way someone would take the time to put all this together in a different thread rather than debate within the original thread.
The end.
