How many of you guys are running a 2 step with spray/ big stall
Im trying to complete my set up and finish the tunning.
Motor is 370 built for a 300 shot heads have been ported
13-2 compression. cam motion custom N20 grind 10 degree spilt
chance stall 4700 na 5100 spray.
PERFORMABUILT T400
thanks for all in the input you guys gave me. I was just hearing with that big of stall and shot that I should get a 2 step. I would like any imput and how you would set it. thanks
PERFORMABUILT T400
I have a 2-step on my TA. Pending on the track prep and the air that day. Say on an bad track, I will leave around 1800-2000 and 60ft in the sub 1.38's. On a good trackI will 2-step it around 2800-3200 and go on average 1.34-1.36's. On a kickass track prep I leave around 4400-5000 and go 1.29-1.30. It took me about 2-4 times at the track making 4-6 passes each time to get the nitrous to hook like it should.
Best advice I can give you is log EVERY pass. My wife logs EVERY SINGLE ONE of my passes at the track. It helps out ALOT!
