in the 9's with a cam only fox
im looking for a good deal on a gopro camera kit...if not,i might have someone take a vid for me...hopefully i'll have my goal met the next go around for n/a and i can put a plate on it....
still on the fence on going there or to farmington..if i decide to go to the rock would you film a couple of videos of my car making some passes from the starting line?
#32
haha be careful calling it cam only being milled .040...some people will jump all over that...
awesome times and raceweight...wow I need no start gutting my car more![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
how big of reliefs did you cut
#35
Billy,
I once called my 6.0 "cam only" and was corrected rather quickly.
Still feel like you, it is a cam only motor with necessary mods to make it work.
heads are milled on an lq4 to get maybe 9.8/1...What is the compression on a stock ls1?
any one ever put a 5.3 head on an LS1 with a cam...is that considered cam only?
Any way, I now run a stock cube 346... :-)
Dave
Dave
#36
it has a 8.8 in it thats been cut down a few inches on each side to run a more evenly offset rim...aje front end stuff and has the stock style rear suspension also with a anti roll-bar from team z...its even still got the factory rear shocks on it(until i can find a good deal on some adjustable ones)...thanks billy
#37
Billy,
Dave
Dave
