Carter01 goes 9.97 @ 133.26 today!!!!
#41
thanks guys for the props. Sorry for the late responses, I don't view this section very much.
Pump gas I only ran a 150 shot, not that you can't run more it's just that i was learning and didn't want to fry any parts.
Just finished my latest upgrades yesterday.
- Race Style true duals with Dynomax Bullets
- upgraded from -4 line to a -6
- upgraded from a .88 jet to a .93 jet
- deleted HVAC which was 45lbs
Headed out this sat to she what she will do in the heat. Hopefully the tune-up we are working at will allow for some better ETs and MPH.
#42
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#43
Ok that's good to know I am going to stay with a 3:42 I will also be running a 28 inch tire also. I think if I have that it will still get out of the hole well. Plus I will be hitting it with a big shot also like I said thanks for the advice.
#44
Previous best (88 jet or 250 shot)
1.35 60ft
6.30 1/8
107 mph
9.97 1/4
133.26 mph
DA -600ish
49 degrees
30.19 Barometric Pressure
30 % Relative Humidity
Last Night (all passes on 93 jet or 300 shot)
#1 Soft tune-up, new combo, needed data
1.41 60ft
6.38 1/8 mile
108.43 mph
10.01 1/4
135.36 mph
Pass at 14.5 degrees
#2 Put 1.5 in her, Sat on the converter too long and spewed some fluid
1.42 60ft
6.33 1/8
109.21 mph
9.93 1/4 (new best however)
135.88 mph
Pass at 16 degrees
#3 Plugs looked over timed so I pulled a half degree
1.40 60ft
6.25 1/8
109.98 mph
9.84 1/4 (new Personal Best)
136.73 mph
DA +1700 to 1800
77 degrees
29.93 Barometric Pressure
79 % Relative Humidity
1.35 60ft
6.30 1/8
107 mph
9.97 1/4
133.26 mph
DA -600ish
49 degrees
1.41 60ft
6.38 1/8 mile
108.43 mph
10.01 1/4
135.36 mph
1.42 60ft
6.33 1/8
109.21 mph
135.88 mph
Pass at 16 degrees
1.40 60ft
6.25 1/8
109.98 mph
136.73 mph
DA +1700 to 1800
77 degrees
#51
As far as LTs go i really don't know. They were on the car when I bought it 4 years ago. They appear to be something like Pace Ceramic coated 1 3/4s.
BTW- you know my sig pic is the one your wife took back in jan. Big Thanks again!
