8.5 cert requirements
so I have started my build witch I will be posting progress pic BTW so anyways I'm trying to figure out what all is needed for 8.5 cert I already have a 10 point roll cage what else is needed
A 2017 rule book will be your friend on this. Along with the cage being cert'd, and up here the cert guy didn't care the window net wasn't installed, he wasn't inspecting that. Then net is a tech item at the track
So cage properly installed (don't forget the sill bars), net, clothing (gloves, double layer pants and jacket and sometimes shoes), license, and sfi stuff like a flex plate shield ansntrans sheild, sfi balancer, some want the engine blanket installed, parachute for for over 150, stock seats are fine with stock bolts, aftermarket seat needs a back support, proper seat belt installation, drive shaft loop, battery kill switch, there is some fuel stuff like no more than 12 inches of rubber fuel line, but most rubber braid is just fin
It's all in the rule book. Best 10 bucks you'll spend besides paying the man for the cage cert
Edit, don't forget once you get your nhra license, call up summit and jegs and get on there Pro shop discount racer account
