Single Digit Club Running 9s or quicker? Damn!
pic the 88 at the track
Old Apr 26, 2005 | 09:45 AM
nosfedgta's Avatar
Default pic the 88 at the track
Here is a pic I got sent to me today. I had the tires up higher on some other passes, but its a good pic... I had a 1.38 60 that day. I really need to work on my suspension though it spins bad if I put more than a 100 shot on it.. I just dont know what else to di with it at this point... any help would be greatly appreciated...current mods are as follows
spohn torque arm set at -2 pinion angle..
spohn control arms
spohn panhard bar
lakewood 90-10 struts up front
moroso trick springs up front
competition eng. drag shocks in the rear
stock springs in the rear..
Old Apr 26, 2005 | 03:47 PM
02SOMWS6's Avatar
Nice! MY yellow 3rdgen launches all tweaked to the side. I'm still playing with the psi in the airbag.
Old Apr 26, 2005 | 07:15 PM
nosfedgta's Avatar
cool...I had 12psi in it on that pass...... I hope to get my 60's in the low 1.30's
Old Apr 26, 2005 | 08:14 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
don't worry about the air bag, put a good swaybar in it.
Old Apr 26, 2005 | 09:17 PM
My84Z's Avatar
get a nitrous progressive controler in it and shoot less then 100 of the line then go up! BTW those 3rd gens are bad ***!
Old Apr 26, 2005 | 10:00 PM
slow trap's Avatar
is that a glastek hood on your car? oh yeah,have you tried adjusting pinion angle?any thoughts on going to the south side machine lift bars?
Old Apr 26, 2005 | 10:03 PM
PRAY HRD's Avatar
absolutely! got to get a nice solid piece under that car if you don't already. and if you do, you'll just have to do like everyone else.........test and tune. nice job too btw.
Dave
Old Apr 26, 2005 | 10:04 PM
nosfedgta's Avatar
Yes that is the glasstek 4in. -2 pinion seems to work best so far. As for the southside lift bars I have not seen any good reults from them.......
I have thought about the stock location coil over kit though. anythoughts on that setup from anyone ?
Old Apr 26, 2005 | 11:55 PM
LS1Tech Sponsor
Let me know if you try it and what rate springs you are using. I have seen them on 4th gens and I have yet to get any info on springs. I know nosfedta knows what I use, We had a discution a long time ago.
Not to hi-jack your thread but I have gone 9.41 at 146 with a stock style suspension and I have seen the south side kit. I wouldn't put that kit on any car, it just adds weight and it's nonadjustable to boot. I plan on going into the 8's this year and all I'm waiting for is a set of headers and I'm off to the dyno.
Old Apr 27, 2005 | 05:02 PM
02SOMWS6's Avatar
They are junk. I had them and it made the *** end lift instead of squat. I took them off and went with a jegster solid body mounted torque rail.
