Adm. Please enter me in the single digit club.
That run was at the Thunder event a few years ago. I had a ARE 393 all bore engine, and I think close to a 200 shot, NOS direct port. T400, 12 bolt with eaton posi. ET drag, I think that was a 28x10, on a Convo Pro.
I ran a 10 flat run after run, and finally after adjusting the front shocks from full soft, to 3 or 4 clicks firmer, I dropped a full tenth. So, the suspension was unloading after the wheelie. The 60 was a 1.41.
I turned it a few clicks stiffer again, and on the next run, the quick 16, I faced up with Derty, and he got a personal best, but I blew up the rear as the posi took a ****. That was Stenod yelling out at the end of the run, because I finally got a 9 sec run after trying all day.
I was running a stock sway bar, and you can see the torque twist on the car at launch, The rear might have lasted a little longer. I actually blew the tranny when the rear blew (it followed it's way up), and the next year I blew the engine.
So, the setup is different now, and I have yet to spray the new motor, until Wheel 2 Wheel gets the tune right. Should be easy 9's on the spray. Runs 11.00 on motor right now, @ 3500 raceweight. It's a street car, so I have the heavy *** TA seats in there, for comfort, the Kirkeys are in the barn waiting to go in, & there are a few other areas where I can loose some weights. Health issues keep me from doing too much, at the moment.
What motor combo you running now??
I just bought a 98 Z28 with a Lunati 383, NX DP, turbo 400, 12 bolt, and full suspension.
Cant waite to get it to the track!!!
Just hope I can get close to that!!!!
Thanks John. I'll be recovering until Spring. DOnt have any plans to spray the car, but ya never know. I plan on running @ the M-11 event @ Stanton. Just NA for now, and hoping for a 10 sec run on motor, with the nitrous setup.
Thanks KP.
New setup is a Wheel 2 Wheel 402 set up for spray. Iron block. Should be easy 9's on the spray.
Thanks KP.
Congrats on the 10.8x run man! I sure hope I'm about as fast next year. Sorry I didn't get to talk much, but you looked busy
It was beautiful how that front lifted during your launch!
