Single Digit Club Running 9s or quicker? Damn!
Blower Setups
Old Dec 1, 2006 | 10:37 AM
Juiced's Avatar
Default Blower Setups
I'm tossing around the idea of my first blower drag car, what blower units are most high to mid 9 sec running? P1's ot T-trims, or is there a need to go to f1's or YSI's, possibly a x-trim or f1'r?
car has a moser 12bolt with spool, 410 gears, rossler with t-brake, 366 forged ls2 with ported l92's, singleplane intake, accel 1500cfm throttle body and 3100lb race weight if it helps.
Old Dec 1, 2006 | 01:17 PM
kp's Avatar
kp
At that weight you might get in the 9s with a P1 but I have no problem running mid-low 9s @ 3400lbs with a DiSC and a 346 with unported dart heads, LS6 intake, stock TB and 222/228 .550 lift cam. D1SC or F1 would be just fine for what you want to do.
Old Dec 1, 2006 | 05:30 PM
HUNTER02SS's Avatar
I would also loose the 410 gears to something like 342 or 350's.
Old Dec 8, 2006 | 02:46 PM
JMBLOWNWS6's Avatar
My T trim is going to pop me into the 9's I just finished the cage and added some more timing and motorsport 109 FTW
Old Dec 13, 2006 | 09:51 PM
ss496's Avatar
nice setup...will have to check it out sometime
