Single Digit Club Running 9s or quicker? Damn!
Drag Racing Charging System
Old Oct 31, 2007 | 03:03 PM
CTP Racing's Avatar
Cool Drag Racing Charging System
Can anyone tell me if there is a different type of charging system used in a 8.50 sec ls1 drag car? if so, what is in this system?
Old Nov 1, 2007 | 10:19 AM
Twin76mmTA's Avatar
you can do a 16v system, there are battery's with 3 terminals a 16v +/- and a 12v+ for stock computers etc
other than that there really isn't anything different.
Old Nov 1, 2007 | 11:15 AM
kp's Avatar
kp
I'm using a stock alternator rebuilt to 145A output, 10% underdriven and a voltblaster which raises the voltage to 15.5V or so at WOT only and a single 12V optima battery. Been working fine for a couple years now. I dont run 8.50s but close enough
Old Nov 1, 2007 | 01:19 PM
CTP Racing's Avatar
Smile Drag racing Charging system
thanks for the info guys
Old Nov 1, 2007 | 01:22 PM
CTP Racing's Avatar
Default Ignition Blaster
Hey KP what is the blaster all about?
Old Nov 1, 2007 | 01:42 PM
kp's Avatar
kp
Its just a little 80.00 box that plugs into the TPS and alternator made by Casper electronics. At 80% or over TPS its performs some kind of mojo to the regulatorr to up the alternator output. Sort of like full fielding in the old days but not sure how they do it with the CS alternators. But it works, probably costs a few hp but I'd rather have my pumps and ignition at the higher voltage on a pass and its a lot less hassle than the 16v battery thing.
Old Nov 1, 2007 | 05:55 PM
ls1 joe's Avatar
I run no alternator at all. Just one full size optmia red top in the trunk. I have never had any voltage problems.
Old Nov 1, 2007 | 07:29 PM
CTP Racing's Avatar
Default No Charging System
so do you have to charge your battery every pass you make?
Old Nov 2, 2007 | 10:13 AM
ls1 joe's Avatar
Yes but we always did. For the last 2 years it was habbit for me to hook it up right after the pass since our water pump/fans are on cooling the engine.
Amber
