Single Digit Club Running 9s or quicker? Damn!
8 sec Holden
Old May 29, 2008 | 08:38 PM
10sec_rx7's Avatar
7 Second Club
Default 8 sec Holden
i though i should put a thread in here about our car,
specs
1999 VT commodore (basically 4 door GTO)
408ci LS1
2x Garrett T04z turbos
2 speed power glide
stock IRS diff with full spool
BMR stub axles and Drive shafts
custom 2 piece tail shaft
29x9 MT slicks
8.98@160mph
pics
Timeslip
this is where it is at at the moment,
still a lot of work to do and the 7sec pass is only a matter of time..
3/4 chassis by TEX race cars,
GT55 Garrett turbo
new ice box intercooler
Old May 30, 2008 | 06:52 PM
RAGENZ28's Avatar
What size MM are those turbos? 50,60,70's? NM looks like it's a 74/76mm whats the A/R on those?
Old May 30, 2008 | 07:49 PM
10sec_rx7's Avatar
7 Second Club
66mm comp wheels, ar .70 front, 1.06 rear with a P trim wheel
Old Jun 11, 2008 | 11:48 AM
RAGENZ28's Avatar
Those must spool pretty quick.
Old Jun 11, 2008 | 05:51 PM
10sec_rx7's Avatar
7 Second Club
they were not too bad, the converter was a little tight which didnt help but with the new setup the converter should be spot on
Old Jun 11, 2008 | 08:03 PM
RAGENZ28's Avatar
The A/R is low so it should spool fast, I am going with a 1.32 on my 80mm turbos.
Old Jun 11, 2008 | 08:30 PM
10sec_rx7's Avatar
7 Second Club
1.32 will be fine, we were going to change the housings over to them but the 1.06 were doing the job, the car only did 4 passes with the 408 in it all were under 9.2, it did run 9.4@148 with a 346ci in it
it was under turboed with this setup hence the switch to the GT55 for the new setup
Old Jun 12, 2008 | 12:26 AM
RAGENZ28's Avatar
Cool post some update videos when you get them.
Old Jun 16, 2008 | 03:13 AM
1dirtyZ's Avatar
amazing!!!
but could that intercooler be any smaller
what rear suspension setup do you have?
and why are you running 4! 420 pumps ?? ( assuming they are the bosch 420's )
Old Jun 16, 2008 | 05:53 AM
10sec_rx7's Avatar
7 Second Club
Originally Posted by 1dirtyZ
amazing!!!
it was a little on the large side but it flowed really good and had almost 0 pressure drop, but thats what you get when you use quality PWR cores,
the rear suspension is as it left the holden factory, standard IRS, standard control arms, bilstien shocks, BMR drive shafts and stub axles, stock diff with full spool, very basic setup,
the pumps are 2x 044 600hp and 2x 910 which are 350hp, when worked out the flow of the 2x 044's the injectors would flow more than the 2 pumps can pump so 2 extras were added for safety,
Old Jun 16, 2008 | 07:25 AM
1dirtyZ's Avatar
wow! what size injectors are you running?
how long before its running again?
Old Jun 16, 2008 | 06:24 PM
10sec_rx7's Avatar
7 Second Club
it was running 79lb racetronix injectors off the factory computer with a HP Tuners 3 bar os,
the new setup is 8x 79lb and 8x 28lb factory LS6 injectors, that will give us enough fuel to make the 1500hp on C16, it will be running 2x factory computers with 1 just running the 28lb injectors and the other runinng the ignition and 79lb injectors
im guessing it will be running by the end of the year
Old Jun 17, 2008 | 02:22 AM
1dirtyZ's Avatar
now thats an interesting setup! please keep us updated !
not to be sarcastic, but why didn't you go with bigger injectors ( say 120 lbs/hr ) and an impedance converter??
Old Jun 18, 2008 | 10:36 PM
10sec_rx7's Avatar
7 Second Club
i tested 3 different converter boxes and none of them worked well, the car ran fine but the difference in the egt's between cyliders was a big worry, as soon as they high injectors were put back in all the cyliders were back to with in 30deg of each other,
thats one thing the data logger will tell you that you would other wise think everything was fine, the AFR's out the pipes were perfect, but some of the cyliders were rich and some were lean
Old Jun 19, 2008 | 04:57 AM
1dirtyZ's Avatar
interesting point you got there , never looked at it that way.
Old Jun 19, 2008 | 06:21 AM
10sec_rx7's Avatar
7 Second Club
i was quite shocked at the state of these boxes, with out EGT logging on each cylinder you would never know there was a problem till you burnt up a few pistons,
some cylinders were 600 deg c and some were 800 deg c and this was only on 15psi, on 20psi would just make the problem worse..
