BBC in 4th gen
Too late I already cut out the fire wall I don't care if it is super fast, I just want a bad *** pro street looking setup I can drive everyday of the week, plus putting the smash for a quick 300 ft at a stop light on some ricer would be great every now and then =)
Going pump gas this time with big motor and good cylinder head, it's 900+ hp or bust N/A. I wasn't thinking anything crazy, looks like I can go from 0-6" on how I am doing the firewall and going to tie in the cage and mid plate mounts. I am going with a lexan front window so I can notch it out for carb clearance.
Under the hood I am doing a wide fire wall, not just a set back section in the middle so access should be super easy with the rear of the shock towers cut out.
I'll try to get some later I haven't had time to do much been getting stuff ready to ship out I sold and doing other stuff. Tomorrow I will have a good amount of time so I will try to get some more work done then take pics.
What's up with your car where is your updates?
Me? I don't want to take things too far off the topic, but I haven't done much since getting it running. I'm waiting on a used rack + pinion as mines leaking. I'm still trying to figure out what I want to do for a radiator and condensor. I could go with a 40" x 12" in the center or twin 15"x18" units under the headlights. I want to get rid of the stock radiator mounts completely, that whole header panel, too. I'm trying to figure out the best way to rebuild the front with tubing.
I also plan to tub the front wheel wells so I'm making sure I take everything into account.
Let me know....
I know of only one guy to tub his front wheels, but I've never seen anyone do what I plan to do so I just need to think everything through real well.
To support the nose I plan to run some tubing right along the front. That's mainly in case someone leans on it. I'll be using a fiberglass nose so it will be fairly stiff as is.
When you saw notch the front, do you mean the wheel tubs for tire clearance? I think about 2". I want to bring the wells right up to the hood if possible.
Bags and drop spindles are the plan. I've already worked out the bag part, but I'm still working on the spindle idea.
Do you still have your power steering pump? I may need one.
Those noses don't need any support. The guy making them and his customers don't use any, but you have to be carefull about people leaning on them. They seem to hold up fine, but I wanted to add a little support for insurance.
Look at vfn's site they have diagrams. Ever consider a custom spindle? I am sure they can go more than 2".
Ever consider cutting off the stock shock towers and making custom upper and lower a-arms? The longer you make the arms the less it will change the geometry when you raise and lower it., then you could mount an air bag and shock setup out of the way and have full clearance to the hood above the tire, that thing would sit on the ground big time.
Below on some pics of the style of support bar I want to make as well as the E-1 front end. Since I don't need an intercooler I was thinking of mounting the radiator and condenser in the nose to make it look decent. Another option was to use a grill behind the openings.
2" will have the k-member on the ground. I don't need any lower.
Who makes custom spindles? (I can't afford $2K for billet units.)
