357 SBC w/ Vortec heads
this is true but i think ill wait for a cam when i can afford a performer rpm intake and double pumper carb and a 400 crank so i can go stroker!
You can run a stock 400 crank and rods (5.565") and a stock 350 piston to get a 383 though not ideal.
DO NOT listen to the dope smoker and get a 4000 converter as its waaaay more than you need and will only hurt you rather than help. Sorry 420 man but your plain wrong about that its a heavy ride......
A 2500-3000 converter is PLENTY for your package and the weight of your car, also dont waste money on a camshaft thats too big as well. Keep it simple and use a moderate hyd roller in the 238*-244*ish @.050" range and around .525-540" lift at most with your heads and compression that should be more than sufficient. Bigger is not always better, and when your heads flow a certain max number at a given lift going more lift will not increase flow or power in any way shape or form so its a watse on can actullly cost you power down where it really counts on an engine like this.....
thanks a lot i might throw a 400 crank n rods in sometime but idk when and since im bored over .040 what would that be like 386 or somethin? but i was planing on like a 3000 to 3200 stall i jst found a clone gnx converter that flashes 2500-3000 with lock up still brand new for only 350 good deal? and i was also thinkin bout gettin 1.6 or 1.7 rockers cuz i have factory ones and they arent roller and that would give me a lil more lift
There's a place called Redneck that makes some very good converters for the money, and you can find them on eBay they have a store. VERY GOOD for the money, I had so spend $1200 for a 9" Continental Steel stator nitrous converter LOL! So be thankful you can get away with a very modest converter......
wow! lol my dad had gone thru a lot of converters a guy at BTE told him that when he cut it open the fins inside were rolled up into ***** and rolling around inside!
#35
Both if possible, I sometimes install a tiny pipe plug to drain the converter, though you get an idea of how things look when you drian the fluid from the pan as its the same throughout. Its not really a must to change it after every trip, but when your making over 1000hp at the crank its not a bad idea to keep an eye on everything. Better safe than sorry IMO... I always have several gallons of Mikes fluid on hand, and that stuff aint so cheap if ya know what I mean....
A Mikes Transmission is by far the best I've ever owned and a bunch of my buddies agree, I even had a Rossler TH210 in my drag radial 71 Chevelle when i sold it and like the Mikes better.
#37
never heard of mikes either but i currently have a redneck th350 & stall that flashes around 4300 and have had no troubles from either. like above, if you get a good convertor then you will be money ahead.
#38
sweet i am def planning on getting a decent street/strip converter and hope move my car into the 8.4s in the 1/8th and maybe some 13.3s?? i wish i could it over 100mph but im gonna guess around 98 99
