Any familiar with 350 TBI engines?
My question is, a 350 TBI out of a '92 truck, what type of heads would it have? Would it take the 4 bolt intake versus the 6 bolt? I assume the heads would not be angle plug heads. I have not seen the engine to be able to see it for myself.
Thanks.
Thanks.
Inside the port they have a ramp that is supposed to give the fuel/air charge a swirl. Instead it chokes the ports down.
They are the worst flowing head GM ever made.
Good for low end torque to maybe 4000 or 4500 if you're lucky.
They have 6 bolts per side and the center bolt holes point more upward, meaning you'd have to slot the holes on an old style intake.
They are straight plug, GM hasn't put angle plug heads on a production GEN 1 since the early 70's.
Yes, different heads are a must. Yours are likely #193 or 191 and they are the swirl port, low perf, truck heads. The block has the provisions for a roller cam/lifters, but I have never seen truck engine with a roller before 1995.
