BBC conversion cost
BMR trans mount $100-$150 (they have them for most trans)
Hooker headers, PN 2455, $175
Driveshaft $150-$300
Manual Rack (bolt in) $650, (weld in) $300 (includes steering shaft and knuckles).
Depending on how much fabricating you want to do, it could be installed for as little as $700 to $900.
motor plate/ mid plate setup makes life easy getting the motor in and out.
burkhart chassis k-member kit with bump steer kit, lower control arms, manual rack etc
afcos
drop spindles
aerospace brakes
driveshaft
powerglide
Of course, Time IS Money, and I do have a good bit of hours in this build.
To each his own...
Just out of curiousity, what kind of power are you planning to make (w/adder)?
I've put 750-800 FWHP to my car so far. The only problem I've had so far is the front wanting to twist a little. I'm fabbing a front plate that should cure that.
A good friend of mine is a pretty good welder. He's done many frames and tubbing jobs around the area... I'm considering just having him fab up a motor plate and 'throw' it in that way...
like i stated earlier. mostly drag some street use... so the heater and everything else will be gutted
