Good 350 shortblocks?
I've contacted a few dealers and they all say that their shortblocks (complete with forged pistons and I-beams) are good up to 500HP. Funny thing is, I've pushed a stock bottom end 350 a little beyond 500HP so I'm not looking to splurge money on something that I could do without.
The ones I'm looking at right now are:
http://www.schwankeshortblocks.com - Level 1 350 Chevy Short Block
http://www.proformanceunlimited.com/...eme_short.html
Haven't been able to find much info on either one of them.
Am hoping to squeeze at least 425hp to the wheels through the TH400 in a 1900 lb car, and just looking for a cheap yet reliable route.
Here is a pump gas motor with a warranty...
https://www.patriot-performance.com/...&cat=69&page=1
As for the motor from patriot, I just need a shortblock...
I've got some 50cc heads I would look to try on some flat-tops /w 7cc valve reliefs for 12.1:1 and E-85. These same heads netted me 490hp pump gas on a stock bottom end 350 last year. I want to bump the compression up and run the E-85 with a slightly larger cam and shoot for at least 550-600 at the flywheel.
Car they are going in is very very small and lightweight. A buddy of mine has a similar setup in an old 2200lb dodge colt and runs 9.70's /w only 450whp.
I'd consider it but I'm on an extreme budget. I don't think I can go over $2000 on a shortblock, $2500 is REALLY pushing it. The closer I get to 600hp, though, the better. Maybe I'll try and find someone that sells them with Scat rotating assemblies in them. I-beams and flat tops are a must.
I'll have to get one with a forged crank and 4-bolt mains. Going to spray a 100-shot on it as well.
4.170" bore. Chevy Bowtie block, splayed 4 bolt roller cam block (not flat tappet SB2 block). Clevitte cam, main and rod bearings, Braynt 3.260" crankshaft std. mains and rods, Dyers 6.200" rods with 2.00" pins, JE pistons and ring set. FRESH and ready to race.
Piston dome volume is -9cc, 13:1 with 42cc heads.
Looking for 3,200.00 but open to reasonable offers.
