Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
pro comp heads???
Old Jan 15, 2009 | 06:20 PM
mean94lt1's Avatar
Default pro comp heads???
i recently got a 84z in a trade i did has a 383 im putting together for it shortblock is together was wondering what you guys think of the pro compp heads i got the 190 runners 65cc chambers put good valves in them and good springs i am running a comp hyd flat tappet cam p its the 290h cam also was wondering if anyone else is runnning the same cam?
Old Jan 15, 2009 | 07:31 PM
ZONES89RS's Avatar
In-Zane Moderator
I hear those heads can have soft spring seats, but other than that, with port work they do ok.
Old Jan 16, 2009 | 09:19 PM
mean94lt1's Avatar
ok im hearing that they drop valveseats i just dont want to hurt the motor hope they work ok
Old Jan 17, 2009 | 01:48 AM
ZONES89RS's Avatar
In-Zane Moderator
I would spend the extra money on theese...
https://www.patriot-performance.com/...&cat=40&page=1
They flow better than comp and are renown for not being JUNK and having any issues other than reliability and excellent quality for the price.
Old Jan 17, 2009 | 07:10 AM
69Camaro...'s Avatar
i have the 210CC and they are stout heads. Read up on google and other forums, A lot of people use them and are getting awesome results. You get even better results with porting and upgrading the springs.
Old Jan 17, 2009 | 09:50 AM
mean94lt1's Avatar
as i stated above i already have the heads i was just wondering some opinions on the heads thanks i might have them ported but i already torqued them so well see how they perform unported this season next year ill port them and go with a solid roller cam if they hold up
Old Jan 17, 2009 | 11:44 AM
ZONES89RS's Avatar
In-Zane Moderator
Let us know how it goes and how it runs man.
Old Jan 17, 2009 | 12:20 PM
mean94lt1's Avatar
will do would love to do a roller cam their just really expensive when your using a 2 piece rear main oe flat tappet block the retro fit cams are expensive unless you know of a less expensive way to do it let m eknow
Old Jan 17, 2009 | 02:06 PM
ZONES89RS's Avatar
In-Zane Moderator
Extra 500$ is worth it to me, no issues with break in or running special oils and what not, or too much spring pressure, all that.
Old Jan 19, 2009 | 11:18 PM
bigbadblack93z's Avatar
Are the rest of the EBAY heads I keep seeing Pro Comp? some of them look like the ZZ3 casting and some look like a Dart knock off w/ the exhaust side completely machined.
I found a set for $600 that are 210's but the flow numbers sort of suck, somewhere in the 250 range @ .600. You'd figure even unported a 210 would start out a little closer to 270
Old Jan 20, 2009 | 01:41 PM
89305formula's Avatar
i have a set of procomps with 190 runners and i had them milled down to 60cc and my little 305 runs pretty well with them along with a comp 276hr cam
Old Jan 20, 2009 | 01:59 PM
mean94lt1's Avatar
ok thanks for the input looking at going solid roller now just not sure if i want to spend the money right now
Old Jan 20, 2009 | 04:11 PM
heavy6.0's Avatar
they are chinese crap, stay away!!
Old Jan 20, 2009 | 09:18 PM
care to elaborate on that? do they need machine work to be usable or is the metal of such poor quality that they won't seal or do they warp, etc?
I'm wanting to build a quick car on a tight budget(who doesn't want that?) and to save $600 on a set of heads would be money that could be spent on nicer wheels or rear end parts, etc.
Old Jan 20, 2009 | 09:56 PM
KCS's Avatar
KCS
Moderator
I've seen some Pro Comp BBC and SBC heads, both seemed decent and neither had any problems on the dyno (that I know of). The BBC heads had new valve seats installed, and we found that they had used loctite around the seat insert (no-no). Other than that, they seemed fine.
Old Jan 20, 2009 | 10:13 PM
ZONES89RS's Avatar
In-Zane Moderator
Tell them...tell them the beloved Scat and Eagle forgings are imported....
Old Jan 21, 2009 | 06:27 AM
mean94lt1's Avatar
this thread is really starting to scare me
Old Jan 21, 2009 | 07:09 AM
pancherj's Avatar
I believe the Scat cranks are purchased as raw forgings and fully machined here in the US. I'm not sure about Eagle. However, I have heard of several problems with Eagle crankshafts (poor indexing of the throws, new cranks that were bent, etc.). I work for a large manufacturer asan engineer and we deal with China all the time. If you have a good quality control program in place, you can force them to make a decent product. If not...you WILL get garbage!
As for the heads...people said the same thing to me when Trick Flow first came out. I bought an early set and they were great. I did try to weld repair an area once and found that the grade of aluminum didn't weld very good. I think they are even better now.
Old Jan 26, 2009 | 09:53 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
The only way they would not weld up nice is if you used the wrong grade of rod.
__________________
Old Jan 26, 2009 | 11:21 AM
kenSS's Avatar
Scats forging are done overseas but the machining of the finished products is done in california.
