Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
454 block question
Old Feb 27, 2009 | 11:02 PM
ls1foxcoupe's Avatar
Default 454 block question
Are there good blocks and weak blocks that gm made. I have heard that some blocks are thinner, anything to this?
Old Feb 28, 2009 | 01:40 AM
ZONES89RS's Avatar
In-Zane Moderator
Not exactly, the "bad" blocks were really just the smal cube motors and the newer blocks that do not have huge aftermarket support like the old ones.
Old Feb 28, 2009 | 12:30 PM
slow95z's Avatar
bad blocks have cracks in them from slung rods etc., other than that no problem with a 454. build it with good parts and you will be fine.
Old Feb 28, 2009 | 12:44 PM
JUICED96Z's Avatar
I have been told the 70's blocks are the ones you want and a early 70's is even better. I just sold my 1970 .060 over block for $75.
Old Mar 4, 2009 | 03:27 PM
raped 95Z's Avatar
to my knowledge and my reasearch if the 454 block has the stamping on the back of the block saying "Hi Perf Pass" it is usually a high nickel block which is suppoed to be stronger than others
Old Mar 4, 2009 | 03:56 PM
JUICED96Z's Avatar
Mine had that and I was told that it really just meant that it came out of a car and not a truck and that the casting year was more important.
Old Mar 18, 2009 | 04:18 PM
chevellepowered's Avatar
me performance parts for the older ones.. i dont think any one really builds the newer ones.. i may be wrong.. 4 bolt the best.. but two bolts i have seen a 2 bolt with blower 800 h.p.. could always convert a 2 bolt into a 4 bolt..
Old Mar 18, 2009 | 06:13 PM
ZONES89RS's Avatar
In-Zane Moderator
Correct, it is "High Performance Passenger Car" basically.
Old Mar 18, 2009 | 06:46 PM
xx_ED_xx's Avatar
Is building a newer one. The nice thing about the newer ones is hydraulic roller cams and the gen VI they moved the oil galley up next to the camshaft so 4.370 stroke with out any grinding.
Old Mar 22, 2009 | 04:01 PM
dang son, i gotta do my research, i might go with bbc again,
