Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Throttle cable setup for SBC in 4th gen?
Old Mar 25, 2009 | 07:50 PM
southerntp's Avatar
Default Throttle cable setup for SBC in 4th gen?
I have put a 421ci SBC into a 2000 camaro, stock suspension car to run ORSCA modified street. I have almost everything planned out perfectly except for the throttle cable setup. What are most of you guys running to make this work? Please list make and part numbers if possible. Oh yeah, I am going to be running a 4500 dominator carb. Thanks in advance
Old Mar 25, 2009 | 08:06 PM
ZONES89RS's Avatar
In-Zane Moderator
I stole that cable out of a third gen on my 95 Z. Has to be a TBI V8 car or a original carb equipped ride.
Old Mar 25, 2009 | 08:13 PM
southerntp's Avatar
what carb are you running?
Old Mar 27, 2009 | 05:58 AM
southerntp's Avatar
come on guys help me out here. I need to get these parts ordered as soon as possible. I need your help.
Old Mar 27, 2009 | 08:04 AM
raped 95Z's Avatar
just buy a universal cut to fit steel braided one from LOKAR they are tit to install....
Old Mar 27, 2009 | 09:29 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Ditto on the Lokar cable. We have them if you need one overnight.
Old Mar 27, 2009 | 10:24 AM
xx_ED_xx's Avatar
Pick up an issue of street rodder. They have all kinds of neat custom stuff
Old Mar 27, 2009 | 12:01 PM
ZONES89RS's Avatar
In-Zane Moderator
I am running a holley 750.
Old Mar 27, 2009 | 12:40 PM
southerntp's Avatar
do you have a part number on the lokar cable? Also any other mounts that I will need. List all part numbers needed for all of the mounts, brackets, etc. Going from stock to this. Thanks
Old Mar 27, 2009 | 06:13 PM
ZONES89RS's Avatar
In-Zane Moderator
I used the random carb throttle linkage mount from the parts house performance wall.
Old Mar 28, 2009 | 08:32 PM
southerntp's Avatar
any part numbers or places that I can buy them at?
Old Mar 28, 2009 | 08:49 PM
ZONES89RS's Avatar
In-Zane Moderator
I cannot remember the part number, it was on the wall at Oreilly. I will see if i can get it when i stop by again.
Old Mar 28, 2009 | 09:51 PM
southerntp's Avatar
Alright man thanks alot.
Old Mar 30, 2009 | 10:35 AM
nubby1's Avatar
i have the same set up in my 01 ws6 i went with the lokart cable dont have the part # but it was a universal cut to fit
Old Mar 30, 2009 | 02:58 PM
southerntp's Avatar
Did it come with mounting bracket and everything? Just want to make sure that once I order this cable, that it will be the only thing that I will need to make this work. That includes bracket, and clips, and everything. Thanks
Old Apr 3, 2009 | 08:41 AM
LS1TECH Sponsor
You will need one of these, http://lokar.com/product-descriptions/srk4000.htm, and one of these, http://lokar.com/product-description...hrotcables.htm, the part number is TCP-1000HT36 36" Polished Hi-Tech Throttle Cable.
Hope this helps, if you need to order it, I can get it for you.
By Brett Foote | 2026-06-04 05:00:17
