Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Procomp heads
Old Apr 5, 2009 | 05:04 AM
Midnight's Avatar
Default Procomp heads
Any body have any experience with procomp heads? Here are the specs:
2.02 and 1.60
190cc Intake Runners
64cc Chambers
Intake Flow Exhaust Flow
.100 58.0 .100 52.0
.200 113.5 .200 97.8
.300 159.2 .300 132.94
.400 199.7 .400 161.90
.500 227.6 .500 180.00
.600 244.2 .600 189.2
.700 248.3 .700 192.1
Old Apr 5, 2009 | 07:44 AM
xx_ED_xx's Avatar
I am not sure on the sbc heads but i had a set of the BBC heads and the machine shop i took them to. Said to get rid of them. Something about dropping seats out of the heads and destroying motors
Old Apr 5, 2009 | 12:35 PM
ZONES89RS's Avatar
In-Zane Moderator
Spend the extra money on a set of Patriots and dont look back man, they are not much more and are renowned already for performance and quality.
https://www.patriot-performance.com/...&cat=40&page=1
If you dont need aluminum, theese are cheaper and work great(wish i would have bought them):
https://www.patriot-performance.com/...ome.php?cat=76
I would rather use the cast iron and know there is quality or use the extra 300$ knowing that my motor is not going to be destroyed beating the hell out of it and get the aluminum.
Old Apr 6, 2009 | 11:17 AM
NemeSS's Avatar
i have set that flow more those with a smaller runner.
and made in USA
Old Apr 6, 2009 | 02:14 PM
calebzman's Avatar
I've been using a set for a couple years without issue. Here's a similar thread: Pro comp Heads Product Review
Old Apr 6, 2009 | 08:09 PM
jester1's Avatar
Junk. Sorry.
Old Apr 6, 2009 | 09:02 PM
KCS's Avatar
KCS
Moderator
2.02 and 1.60
64cc Chambers
.100 58.0 .100 52.0
I've seen a few sets, never seen any have any problems though. I think it was a Pro Comp head I saw that had loctite to keep the seats in . Not a great head, but probably not bad either.
Old Apr 7, 2009 | 03:01 AM
bnio's Avatar
You should do some more iquiring about these heads. I have heard these have been coming from china and quality control was bad. When it comes to heads you usually get what you pay for. The Rhs or enginequest iron stuff should be pretty good. at gofastnews.com, david vizards website there is a good right up on the eq stuff under technical articles. If I remeber correctly the rhs and eq are basically pro action heads and i have ported those with great success (big airflow) very easily. Don't know your budget but this is the most important investment so buy something good. And don't buy extremely small ports if you want power, I would say 190cc min. I have no idea why people buy 180cc size ports, that just freakin tiny.
Old Apr 17, 2009 | 02:08 AM
jag327's Avatar
Hi I'm new to the forum, I just bought a set of procomp 210cc sbc with 58cc chambers
1.6 roller rocker arms 2.02/1.60 valves 550 lift springs +100 push rods paid $720.00 for everything my machine shop guy check them out and said these would be good for the street rod or mild drag car with porting the will come alive, He said there was few in the pass that needed cleaning up this was about 2 years ago. And he said some shops been been putting the heads down because they sale the higher price 1's and sometimes the higher price heads need cleaning to.
Old Apr 17, 2009 | 02:55 AM
jag327's Avatar
Check this right up out on the procomp heads
http://www.musclemustangfastfords.co...est/index.html
Old Apr 17, 2009 | 09:19 PM
STREETRODZ1's Avatar
I like the Pro Action heads, they are reasonable, and i have seen some great figures and performance out of them, not sure about the Pro Comps though.
Old Apr 20, 2009 | 02:52 PM
TT632's Avatar
X2. I wouldn't put those heads on a stock motor when you have Dart, Brodix, or AFR heads available, that won't lose their seat integrity.
Old Apr 21, 2009 | 04:05 AM
1bdbrd's Avatar
Where have you found results for the Patriot heads? I haven't been able to find any 3rd party results yet..
Old Apr 21, 2009 | 09:08 AM
jag327's Avatar
Shop that told me about the Procomp heads is Supercar Automotive Malcolm Durham speed shop now run buy is Brother Donald Durham after showing me a few heads and testing them these Procomp heads was the best bang for your money out of the box now they have step up there workmenship on the heads and just about every 10 motors that come to the shop 4 are running Procomp heads. He said after porting the procomp heads on 383 motor with 775 cfm hp was 6200 rpm 558 hp at the fly wheel the cam was schheider lift was 537/540... in a street car / mild drag car. the porting on the heads was light. He had 7 motors with these heads install - World,Dart,AFR,Trick flow,Brodix,RHS,Canfield, the shop guy said for what I was doing the procomp heads is all I need, I just could not see my self spending $1400.00 to $2500.00 for set of heads. I'm building a street car may see the track but not sure. O if your running 600 or higher lift cam he said porting the heads would be best can give you some very good flow numbers...
I been checking a lot shops and the net about a lot of heads.
They cost me total $720.00 Procomp 210cc 2.02/1.60 valves 58cc chambers 1.6 roller +100 push rods 7/16 studs and guide plates. He bought the heads bear and install everything.... The shop guy said it's best to buy the heads bear or find a shop that buying them bear so they are check and build to order...
They said there his not been any heads Procomp that came back to the shop for repair..
Every 1 been very please with the. There are some people just can't put out $1400.00 to $2500.00 for a set of heads.. Over here in MD a few of the drag strips people are running the heads...
Old Apr 21, 2009 | 12:13 PM
ZONES89RS's Avatar
In-Zane Moderator
I have no direct info, but all my buddies that have used them could not be happier, especially for the price. Dyno wise, my buddies 01 Z28 put down 414 RWHP with shitty exhaust, Patriot stage II with cam and tune(conservative for break in).
Old Apr 26, 2009 | 07:43 PM
Midnight's Avatar
It's just a street car thats driving for 5 months or less. And usually only a few days out of the week. I think im gonna get a set.
Old May 3, 2009 | 02:35 AM
jag327's Avatar
I paid for all this, Procomp heads 210cc 58cc chambers, 1.6 roller rock arms 7/16 ARP studs, +100 push rods,Air gap rpm manifold,775 cfm dp cab,schneider cam and lifters, 6 gauges from oil temp to ,valve covers,ignition system,gaskets,heads studs ARP, some items I may lift out, total $1389.45, In MD there's a lot of drags race cars running procomp heads.. There's 1 guy I no with 327 small block 40 over with these heads running 545 hp pump gas no nos all motor.
Was trying to load a picture but could not get it to come up....
Click on the link there's some pics of the heads
http://www.cardomain.com/ride/3200563
http://i272.photobucket.com/albums/j...327pics047.jpg
Old May 3, 2009 | 03:33 PM
Midnight's Avatar
Hey Jag, so how long have you been running this setup?
Old May 3, 2009 | 05:02 PM
jag327's Avatar
I just got them in.... but a freind of mind he has 327/40 motor that he had the heads install last year install in May of 08, hp out 327 -545 hp- if you click on the links I posted you can see the heads.
I had the the procomp 64cc heads and sold them and bought the procomp 58cc heads.....
For the price of the TFS or AFR heads look at all the items I was able to buy.
Buy the heads from a machine shop or some 1 that go's through them. I talk to few shops and speedunlimited they are up the street from me. The thing every 1 said you will not see high flow number unless your running a big cam lift around 600 and up... that's when porting comes in to play. Summit put the heads down about a year ago now they said
good heads, Jegs selling them now. They are really catching on. Super Car automotive
had about 8 heads set on the bench for me and showed me flow numbers and how the motor can lose power if the heads or to big. It's hard finding people to be true about things... For me I'm looking to save money. Way anything out and check the net....
Procomp has clean up the act from a year or 2 ago.... I no 12 people running the heads
and are very happy. Like you I and to find people that use the heads. And the shop guy showed me how to port the heads my self.... to.
I can email you pics of them jagcompany@aol.com
also check this out this right http://www.musclemustangfastfords.co...est/index.html
could not up load pics.
Old May 20, 2009 | 11:27 AM
jag327's Avatar
Default Procomp heads install 210 runner 58cc
I got the heads on the motor, compression 11.2 with the procomp 210 runners
58cc chambers motor 327 30 over motor, blue printed steel crank, gear drive,
schneider race cam, 1.6/1,65 rockers TRW rods and butter fly type pistons the black NASCAR rpm air gap manifold,780cfm dp holley carb with a 1.5 open spacer,mallory ingintion hyfire 6al - procomp 2 wire distributor and procomp coil, the little motor is light and strong running man torque is un-real street tires just smoke when coming off the line 373 gearing passenger front wheel come off the ground about 4" to 6" after 1200 miles on the motor I run the car 3 times last car 72 chevelle 454/40 motor no nos, I beat him buy 1.5 cars
lenth we both did not think I would beat him... only shaft at 6500 rpm cam will spin to 7500. For the money I'm happy with the set up... My HP shop guy
would like to dyno the motor he thought I was over 490 hp that for sure the chevelle he said hp 545 with a 410 rear gear... He said the schneider cam I install in the motor works very well with the set up...
I paid under $1400.00 for all this click the link, I could not up load a picture...
http://i272.photobucket.com/albums/j...csneads135.jpg
