What do ya think?
I believe the specs for the cam are with 1.5 rockers, so the 1.6's will bump it up some.
"Recently we ran across another solution. Comp Cams' new "beehive" or conical valvesprings are similar to those used on GM's Gen II production LS1 and LS6 engines. These springs are wound with an ovate, or oval, wire that creates more room for valve lift before the spring reaches coil-bind. In addition, the smaller beehive design reduces the retainer diameter and weight, which helps the spring do a better job of controlling the valve at high rpm. But perhaps the best news of all is that these springs will bolt right onto a stock Vortec head with no machining required. These springs also increase the amount of available valve lift from 0.450 to 0.550 inch. (The spring can accommodate as much as 0.665-inch lift, but when installed at 1.800-inch height, the retainer-to-seal clearance limits lift to slightly more than 0.550 inch.)"
The problem is, with your 1.6 rockers you valve lift will be .544/.555. You generally want more clearance on the exhaust and you've actually exceeded the max lift at installed height. You could probably play with the installed height a bit, but that's going to affect you seat pressure and IMO your taking these springs too close to the edge with the 1.6's anyway. You may want to consider sticking with 1.5's or do 1.6 on the intake and 1.5 on the exhaust, a very common sbc mod.
