Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Which heads for 400 sbc?
Old May 7, 2009 | 09:28 PM
SamW's Avatar
Default Which heads for 400 sbc?
Which head would be the best all around performer for under $1500? Mainly I've been looking at either Patriot or AFR but I'm really open to suggestions.
Old May 7, 2009 | 09:31 PM
SamW's Avatar
I forgot to add, I was looking at the 195 AFR's or the 225 Patriot's.
Old May 7, 2009 | 10:51 PM
fast01's Avatar
I'm partial to the 195 AFR's.
Old May 8, 2009 | 01:38 AM
ZONES89RS's Avatar
In-Zane Moderator
Bang for the buck, Patriot, higher price but outstanding performer, AFR.
Old May 8, 2009 | 06:08 AM
SamW's Avatar
What would the difference be in power between the two?
Old May 8, 2009 | 06:11 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, the Patriot heads are great, especially for the price, but AFR is top notch and will edge out the Patriots by a bit, is it enough to spend extra money on....i dont think so, but others say differently.
Old May 8, 2009 | 09:39 AM
kenSS's Avatar
i just built a 383 and a 358 in last two weeks and they both got AFR 195's. they are a great head. pricey but nice.
Old May 8, 2009 | 02:30 PM
moge11's Avatar
AFR 210 ALL THE WAY!!! FuKKK the 195's...Too SMALL for a 406ci or a 383 for that matter.
Old May 8, 2009 | 02:56 PM
SamW's Avatar
Anyone agree or disagree?
Old May 8, 2009 | 04:15 PM
ZONES89RS's Avatar
In-Zane Moderator
Nope, a 210 cc runner is the minimum for a 400 if you want to get peak power.
Old May 8, 2009 | 05:32 PM
SamW's Avatar
The 210s will make more peak power but the195s will have more low endand better throttle response corect? How much of a power difference is between the 210s and 195s?
Old May 8, 2009 | 07:20 PM
kenSS's Avatar
i would go with the 210's also. my customer already had the 195's unfortantley.
Old May 8, 2009 | 07:47 PM
moge11's Avatar
Who Honestly cares about a couple of lb-ft of torque below 3500 rpm.
Old May 9, 2009 | 08:17 AM
Ryan02SS's Avatar
I've ran both Patriots and AFR's. AFR's all the way. I'm not saying Patriot heads are bad by any means, it's just that they don't flow as good or make as much power as the AFR's. Look at the flow numbers across the board. The smaller port 195 AFR's wipe out the 225 port Patriot at anything under .500lift. Peak lift numbers are overrated. It's at midlifts .200-.500 is where the power is made.
I vote for AFR 210 Race Ready's for a 400ci at minimum. You really will lose nothing vs the smaller 195 port.
My 385ci in the boat runs the AFR 190's and at 6000rpms its all the heads can handle. If I was going to spin it higher I would need more headflow.
Old May 11, 2009 | 03:14 PM
SamW's Avatar
Any cam suggestions for a full weight Nova with a 4speed and 3.73s?
Old May 11, 2009 | 03:18 PM
R.E.double.D.'s Avatar
No matter what heads you go with send them to chris frank (naste_ss) and you'll be happy
Old May 11, 2009 | 03:56 PM
kokingSS's Avatar
+1 send them to chris and you always be happy
Old May 16, 2009 | 08:37 AM
SamW's Avatar
What would the compression ratio be with flat tops and the 65 cc chamber? Is there any way I could bleed off enough compression to make it run on pump gas?
Old May 16, 2009 | 09:26 PM
DaNkWeEkS-V8Z's Avatar
sorry to jump in this thread but i did a search on the web and this came up! i have a 73 240z witha sbc conversion and a whole bunch of fabed up stuff but any way i took my motor out and got some 225 patriot's 208/160 (flow 300) and want to build a high compression 355 motor (010 block), does anyone know what good reliabe cheap bottom end combo there is out there that would match these heads, this is my first build! i want some decent pistons and rods and im using straight race gas so i know i want some high compression pistons rods and maybe ill use my stock crank or do i need a aftermarktet one??? thanks
Jason
justafastdatsun@yahoo.com
Old May 16, 2009 | 11:21 PM
moge11's Avatar
well bud, u need to start ur own thread for this....But a 383ci would be much better....start a thread and you'll get more replies......
