TBI Injection Gurus?
Of course, my first thought was an empty tank. We ruled that out. Next, I thought it was the pump, so we pulled the line and found flow. Then, we figured maybe it's the rotor on the dizzy. Replaced that, to no avail.
There's something up with the injectors. It'll run if you dump gas or spray carb cleaner into the throttle body. The injectors weren't engaging, so we straight wired one to the battery. It gets fuel and squirts pretty well when hotwired. This leads me to believe it's a relay or fuse related problem. When I get off work, I'm going to run a test light and see if it's getting a pulse. Any thoughts?
