65 396 build ideas??
75-79 Nova
3.73 gears
28-3200 stall
I mainly want a mild street car that'll run in the 12s on pump 91, so if any of you have some ideas for a strong but milder 396, i'd like to hear them.
I ran in the 12's with a 460 and hydraulic cam. Oval ports that were cleaned up a little.
I switched to a solid and it didn't pick up much. Not worth all the extra work.
Not sure about something so small, but don't go crazy. It's the total combination, not just bigger, bigger, bigger.
Good luck.
T0802LC 5296250 "now according to someone that sells these old chevy engines, he said the "LC" was the model it was in, an impala 325hp for 65.
There are also #s just below the front intake rail (above the timing chain) that reads L1H6P1
So if anyone can clarify this for me?? Its a 2 bolt main if that helps.
I just talked to my dad, he said some 65 impalas came with a 396 and 4 speed. good motor and sort of rare.
I have an 11-677-4 cam with lifters Im taking out of my bbc. had less than 50 miles. pm me if interested
I'm looking at the later 75-79 Novas or a Camaro to put it in, there should be plenty of room, i've even thought of getting a 454 block, then making a 427.
that motor is worth something to some people. good luck.
TRW2240NF Pistons 9.6-9.8.1
Moly rings
Clevite bearings
Comp.XE CL11-246-3 274/286 Adv. Dur. .552/.555 lift. 1800-6000 Or
Lunati 60203LK 268 Adv. Dur. .542 lift. 1800-6200
Perf. intake, 750 carb.
