89 350 blazer dies in gear?
its a 89 scottsdale blazer 4x4 with a tb 350. it idles great in park but when you put it in gear it dies? i checked all the vacuum line no dry rot or holes non off. if you give it gas in low you can keep it going until you stop then dies. what to try first. tb is very clean by the way.
A couple wires were on the manifolds. And I found a vacuum hose dry rotted by it was to the master cylinder. And there was a screw missing were the PVC hooks up for the air control
