carb size
up. A damn Q-Jet might do you better than any square-bore Holley
(but I have never, ever been able to rebuild one of those right, the
Holleys are either more forgiving, less of a contraption, or both).
Got a 650 Edelbrock on my Caprice (400) and it's not holding me
back any that I can tell. A bit of an off-idle stumble that I have
not been able to get rid of by playing with the pump. But not a
bad carb in my book (ask me again 10 years from now). And it
fits the Edelbrock Performer manifold and other spread-bore ones
a lot cleaner than the Holleys. If you got a square bore manifold
though, you'd be pretty much Holley bound.
a 750 is too much carb for that motor. way too much. if you are running a vc it will work because the car isn't making enough of a vacuum signal to use the full power of the carb.
i had a 305 with close to 300flywheel horse power and the 600 served the motor great. you have a lot less and the 600 should work awesome for you. if it is running fucked up its either in a rebuild needing stage or you don't know how to set it up. its is really simple. remember also your timing has a lot to do with this issue also. sometimes timing can make a car seem like the carb is ******* up.
