Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
383 cam help needed
Old Sep 22, 2009 | 02:36 AM
djm2475's Avatar
Default 383 cam help needed
Hello, im putting together a 383 with some left over parts....gm 4bolt block,callies crank,scat rods,probe flat top pistons,dart iron eagles 230 with 49cc 2.08intake 1.6 rockers( i know the heads are largebut i have them) super victor intake 830 holley(heads&intake have minor but good porting also set up for flat tappet cam) Now for the big question i have two cams.... !st one
int dur 287 exh dur 301.....dur at 0.50 int 256 exh 265.... lobe 108.8
valve lift int 550 exh 564..........2nd one is a lunati 40119 no card handy..
which should i use? 2800lb car with 4.11 gears powerglide w brake...
maybe someone has a desk top dyno and would not mindplugs some numbers for me!!!!
Old Sep 22, 2009 | 06:27 PM
kenSS's Avatar
I would go with the first one. I had a 383 similar to this and it made 540hp at the crank on pump gas. My heads were 220 also. 49cc seems like a really small CC
Old Sep 23, 2009 | 12:26 AM
djm2475's Avatar
Default cam
if you dont mind what cam did you run in yours
Old Sep 23, 2009 | 08:47 PM
kenSS's Avatar
it was a .255/.260 at .050 and .555 lift. on a 106 lobe sep.
